Datasheet ADXL103, ADXL203 (Analog Devices) - 7
DescriptionPrecision ±1.7 g, ±5 g, ±18 g Dual-Axis iMEMS® Accelerometer
Pages / Page16 / 7 — Data Sheet. ADXL103/ADXL203. 2.60. 1.03. 2.58. 1.02. 2.56. 2.54. 1.01. …
RevisionF
File Format / SizePDF / 867 Kb
Data Sheet. ADXL103/ADXL203. 2.60. 1.03. 2.58. 1.02. 2.56. 2.54. 1.01. 2.52. Y (V/. E (1. 2.50. 1.00. IVI. T L. 2.48. 0.99. 2.46. SEN. 2.44. 0.98. 2.42. 2.40. 0.97. –50
Data Sheet ADXL103/ADXL203 2.60 1.03 2.58 1.02 2.56 2.54 1.01 2.52 Y (V/ E (1 2.50 1.00 IVI T L 2.48 0.99 2.46 SEN 2.44 0.98 2.42 2.40 0.97 –50
Data Sheet ADXL103/ADXL203 2.60 1.03 2.58 1.02 2.56 2.54 1.01 ) ) g g V/ 2.52 Y (V/ E (1 2.50 T 1.00 G IVI A T T L 2.48 SI VO 0.99 2.46 SEN 2.44 0.98 2.42
004 016
2.40
03757-
0.97
03757-
0 10 20 30 40 50 60 70 80 90 0 10 20 30 40 50 60 70 80 90 –50 –40 –30 –20 –10 100 110 120 130 –50 –40 –30 –20 –10 100 110 120 130 TEMPERATURE (°C) TEMPERATURE (°C)
Figure 11. Zero g Bias vs. Temperature; Parts Soldered to PCB Figure 13. Sensitivity vs. Temperature; Parts Soldered to PCB
50 50 45 45 ) 40 ) 40 % % ( ( 35 35 TION TION 30 30 LA LA U U OP 25 OP 25 20 20 T OF P T OF P N N E 15 E 15 C C R R E 10 E 10 P P 5
007
5
008
0
03757-
0
03757-
60 70 80 90 100 110 120 130 140 150 60 70 80 90 100 110 120 130 140 150 X AXIS NOISE DENSITY (mg /√Hz) Y AXIS NOISE DENSITY (mg /√Hz)
Figure 12. X-Axis Noise Density at 25°C Figure 14. Y-Axis Noise Density at 25°C Rev. E | Page 7 of 16 Document Outline Features Applications General Description Functional Block Diagrams Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics ADXL103 and ADXL203 AD22293 AD22035 and AD22037 All Models Theory of Operation Performance Applications Information Power Supply Decoupling Setting the Bandwidth Using CX and CY Self Test Design Trade-Offs for Selecting Filter Characteristics: The Noise/Bandwidth Trade-Off Using the ADXL103/ADXL203 with Operating Voltages Other than 5 V Using the ADXL203 as a Dual-Axis Tilt Sensor Dual-Axis Tilt Sensor: Converting Acceleration to Tilt Outline Dimensions Ordering Guide Automotive Products
