Datasheet ADIS16460 (Analog Devices) - 10
DescriptionCompact, Precision, Six Degrees of Freedom Inertial Sensor
Pages / Page27 / 10 — Data Sheet. ADIS16460. 0.5. f F. 0.4. 0.3. 0.2. Y ER. MEAN. 0.1. MEAN + …
RevisionC
File Format / SizePDF / 707 Kb
Data Sheet. ADIS16460. 0.5. f F. 0.4. 0.3. 0.2. Y ER. MEAN. 0.1. MEAN + 1σ. IVI. –0.1. SEN. MEAN – 1σ. –0.2. MET. –0.3. –0.4. –0.5. –60. –40. –20. 100
Data Sheet ADIS16460 0.5 f F 0.4 0.3 0.2 Y ER MEAN 0.1 MEAN + 1σ IVI –0.1 SEN MEAN – 1σ –0.2 MET –0.3 –0.4 –0.5 –60 –40 –20 100
Data Sheet ADIS16460 0.5 0.5 S) S) f F f F 0.4 o 0.4 o (% (% R 0.3 R 0.3 O O R R 0.2 0.2 Y ER MEAN Y ER MEAN T 0.1 MEAN + 1σ T 0.1 MEAN + 1σ IVI IVI T T 0 SI 0 SI –0.1 SEN MEAN – 1σ –0.1 SEN MEAN – 1σ ER ER –0.2 –0.2 MET MET O –0.3 O –0.3 ER ER EL –0.4 EL –0.4 C C C C A –0.5 A –0.5 –60 –40 –20 0 20 40 60 80 100
104
105
TEMPERATURE (°C) TEMPERATURE (°C)
13390- 13390- Figure 13. Accelerometer Sensitivity Error vs. Cold to Hot Temperature Sweep Figure 15. Accelerometer Sensitivity Error vs. Hot to Cold Temperature Sweep
10 10 8 ) 8 ) g g m 6 m 6 MEAN + 1σ R ( R ( 4 4 RRO MEAN + 1σ RRO E E 2 2 AS AS MEAN MEAN 0 R BI 0 R BI E E T T E –2 E –2 M M RO MEAN – 1σ –4 RO –4 E E L MEAN – 1σ L –6 –6 ACCE ACCE –8 –8 –10 –10 –60 –40 –20 0 20 40 60 80 100
106
107
13390- 13390- Figure 14. Accelerometer Bias Error vs. Cold to Hot Temperature Sweep Figure 16. Accelerometer Bias Error vs. Hot to Cold Temperature Sweep Rev. B | Page 9 of 26 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION READING SENSOR DATA Burst Read Function SPI Read Test Sequence DEVICE CONFIGURATION Dual Memory Structure USER REGISTERS OUTPUT DATA REGISTERS ROTATION Angular Rate Data Delta Angle Data ACCELEROMETERS Linear Acceleration Delta Velocity Data INTERNAL TEMPERATURE PRODUCT IDENTIFICATION STATUS/ERROR FLAGS Manual Flash Update SPI Communication Failure Sensor Overrange Self Test Failure Flash Test Failure Input Clock Sync Failure SYSTEM FUNCTIONS GLOBAL COMMANDS SOFTWARE RESET FLASH MEMORY TEST MANUAL FLASH UPDATE AUTOMATED SELF TEST INPUT/OUTPUT CONFIGURATION DATA READY (DR) PIN CONFIGURATION SYNC PIN CONFIGURATION Sample Time Indicator Precision Input Sync with Data Counter Direct Sample Control DIGITAL PROCESSING CONFIGURATION GYROSCOPES/ACCELEROMETERS Digital Filtering CALIBRATION GYROSCOPES Gyroscope Bias Error Estimation Gyroscope Bias Correction Factors Single Command Bias Correction ACCELEROMETERS Accelerometer Bias Error Estimation Accelerometer Bias Correction Factors Point of Percussion Alignment RESTORING FACTORY CALIBRATION APPLICATIONS INFORMATION MOUNTING TIPS POWER SUPPLY CONSIDERATIONS BREAKOUT BOARD PC-BASED EVALUATION TOOLS Estimating the Number of Relevant Bits OUTLINE DIMENSIONS ORDERING GUIDE
