Datasheet ADIS16488A (Analog Devices)
Description | Tactical Grade, Ten Degrees of Freedom Inertial Sensor |
Pages / Page | 36 / 1 — Tactical Grade,. Ten Degrees of Freedom Inertial Sensor. Data Sheet. … |
Revision | F |
File Format / Size | PDF / 977 Kb |
Tactical Grade,. Ten Degrees of Freedom Inertial Sensor. Data Sheet. ADIS16488A. FEATURES. GENERAL DESCRIPTION
Tactical Grade, Ten Degrees of Freedom Inertial Sensor Data Sheet ADIS16488A FEATURES GENERAL DESCRIPTION Triaxial, digital gyroscope, ±450°/sec dynamic range
The ADIS16488A iSensor® device is a complete inertial system
±0.05° orthogonal alignment error
that includes a triaxis gyroscope, a triaxis accelerometer, triaxis
5.1°/hr in-run bias stability
magnetometer, and pressure sensor. Each inertial sensor in the
0.26°/√hr angular random walk
ADIS16488A combines industry-leading iMEMS® technology
0.01% nonlinearity
with signal conditioning that optimizes dynamic performance.
Triaxial, digital accelerometer, ±18 g
The factory calibration characterizes each sensor for sensitivity,
Triaxial, delta angle and delta velocity outputs
bias, alignment, and linear acceleration (gyroscope bias). As a
Triaxial, digital magnetometer, ±2.5 gauss
result, each sensor has its own dynamic compensation formulas that
Digital pressure sensor, 300 mbar to 1100 mbar
provide accurate sensor measurements.
Fast start-up time, ~500 ms
The ADIS16488A provides a simple, cost-effective method for
Factory-calibrated sensitivity, bias, and axial alignment
integrating accurate, multiaxis inertial sensing into industrial
Calibration temperature range: −40°C to +85°C
systems, especially when compared with the complexity and
SPI-compatible serial interface
investment associated with discrete designs. All necessary motion
Embedded temperature sensor
testing and calibration are part of the production process at the
Programmable operation and control
factory, greatly reducing system integration time. Tight orthogonal
Automatic and manual bias correction controls
alignment simplifies inertial frame alignment in navigation systems.
4 FIR filter banks, 120 configurable taps
The SPI and register structure provide a simple interface for
Digital input/output: data-ready alarm indicator,
data collection and configuration control.
external clock Alarms for condition monitoring
The ADIS16488A uses the same footprint and connector system as
Power-down/sleep mode for power management
the ADIS16375, ADIS16480, and ADIS16485, which greatly
Optional external sample clock input: up to 2.4 kHz
simplifies the upgrade process. The ADIS16488A is packaged in
Single command self test
a module that is approximately 47 mm × 44 mm × 14 mm and
Single-supply operation: 3.0 V to 3.6 V
includes a standard connector interface.
2000 g shock survivability Operating temperature range: −55°C to +105°C (CML) APPLICATIONS Platform stabilization and control Navigation Personnel tracking Instrumentation Robotics FUNCTIONAL BLOCK DIAGRAM DIO1 DIO2 DIO3 DIO4 RST VDD POWER SELF TEST I/O ALARMS MANAGEMENT GND TRIAXIAL GYRO OUTPUT CS TRIAXIAL DATA ACCEL REGISTERS SCLK CALIBRATION TRIAXIAL CONTROLLER SPI AND MAGN FILTERS DIN USER PRESSURE CONTROL REGISTERS DOUT CLOCK TEMP VDD ADIS16488A
001
VDDRTC
11855- Figure 1.
Rev. E Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. Tel: 781.329.4700 ©2014–2017 Analog Devices, Inc. All rights reserved. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Register Structure SPI Communication Device Configuration Dual Memory Structure Reading Sensor Data User Registers Output Data Registers Inertial Sensor Data Format Rotation Rate (Gyroscope) Acceleration Delta Angles Delta Velocity Magnetometers Barometer Internal Temperature Status/Alarm Indicators Firmware Revision Product Identification Digital Signal Processing Gyroscopes/Accelerometers Averaging/Decimation Filter Magnetometer/Barometer FIR Filter Banks Filter Memory Organization Default Filter Performance Calibration Gyroscopes Manual Bias Correction Bias Null Command Manual Sensitivity Correction Linear Acceleration on Effect on Gyroscope Bias Accelerometers Manual Bias Correction Manual Sensitivity Correction Magnetometers Hard Iron Correction Soft Iron Correction Matrix Barometers Restoring Factory Calibration Point of Percussion Alignment Alarms Static Alarm Use Static Alarm Polarity Controls Dynamic Alarm Use Alarm Example System Controls Global Commands Software Reset Automatic Self-Test Memory Management Flash Memory Test General-Purpose Input/Output Data-Ready Indicator Input Sync/Clock Control General-Purpose Input/Output Control Power Management General-Purpose Registers Real-Time Clock Configuration/Data Applications Information Mounting Best Practices Evaluation Tools Breakout Board, ADIS16IMU1/PCBZ PC-Based Evaluation, EVAL-ADIS2 Power Supply Considerations Outline Dimensions Ordering Guide
