Datasheet ADIS16488A (Analog Devices) - 10
Description | Tactical Grade, Ten Degrees of Freedom Inertial Sensor |
Pages / Page | 36 / 10 — ADIS16488A. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 100. 0.3. … |
Revision | F |
File Format / Size | PDF / 977 Kb |
ADIS16488A. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 100. 0.3. AVERAGE. 0.2. °/Ho. +3σ. 0.1. °/sec). ANCE. +1σ. R (. ARI. RRO. –0.1. –3σ. –1σ. OOT R
ADIS16488A Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 100 0.3 AVERAGE AVERAGE r) 0.2 u °/Ho +3σ ( 0.1 °/sec) ANCE +1σ R ( 10 ARI 0 V RRO AN E L AS –0.1 –3σ AL BI –1σ OOT R –0.2 1 –0.3 0.01 0.1 1 10 100 1000 10000
007
–50 –40 –30 –20 –10 0 10 20 30 40 50 60 70 80 90 100 110
209
INTEGRATION PERIOD (Seconds)
1855- 1
TEMPERATURE (°C)
11855- Figure 7. Gyroscope Allan Variance, 25°C Figure 9. Gyroscope Bias Error vs. Temperature
0.001 0.8 AVERAGE AVERAGE 0.6 ) g S) ( 0.4 F +1σ (% ANCE 0.2 R +3σ O ARI R V 0.0001 0 AN Y ER L T AL IVI –0.2 T –3σ SI OOT –1σ R –0.4 SEN –0.6 0.00001 –0.8 0.01 0.1 1 10 100 1000 10000
008
210
1855- 1
TEMPERATURE (°C)
11855- Figure 8. Accelerometer Allan Variance, 25°C Figure 10. Gyroscope Scale (Sensitivity) Error vs. Temperature Rev. E | Page 10 of 36 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Register Structure SPI Communication Device Configuration Dual Memory Structure Reading Sensor Data User Registers Output Data Registers Inertial Sensor Data Format Rotation Rate (Gyroscope) Acceleration Delta Angles Delta Velocity Magnetometers Barometer Internal Temperature Status/Alarm Indicators Firmware Revision Product Identification Digital Signal Processing Gyroscopes/Accelerometers Averaging/Decimation Filter Magnetometer/Barometer FIR Filter Banks Filter Memory Organization Default Filter Performance Calibration Gyroscopes Manual Bias Correction Bias Null Command Manual Sensitivity Correction Linear Acceleration on Effect on Gyroscope Bias Accelerometers Manual Bias Correction Manual Sensitivity Correction Magnetometers Hard Iron Correction Soft Iron Correction Matrix Barometers Restoring Factory Calibration Point of Percussion Alignment Alarms Static Alarm Use Static Alarm Polarity Controls Dynamic Alarm Use Alarm Example System Controls Global Commands Software Reset Automatic Self-Test Memory Management Flash Memory Test General-Purpose Input/Output Data-Ready Indicator Input Sync/Clock Control General-Purpose Input/Output Control Power Management General-Purpose Registers Real-Time Clock Configuration/Data Applications Information Mounting Best Practices Evaluation Tools Breakout Board, ADIS16IMU1/PCBZ PC-Based Evaluation, EVAL-ADIS2 Power Supply Considerations Outline Dimensions Ordering Guide
