Datasheet ADXRS652 (Analog Devices) - 2
Description±250°/sec Yaw Rate Gyro
Pages / Page13 / 2 — ADXRS652* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 356 Kb
ADXRS652* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADXRS652* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADXRS652 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • ADXRS652 Evaluation Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Application Notes
View all ADXRS652 EngineerZone Discussions. • AN-1049: Calibrating iMEMS® Gyroscopes
Data Sheet SAMPLE AND BUY
• ADXRS652: ±250°/sec Yaw Rate Gyro Preliminary Data Visit the product page to see pricing options. Sheet
User Guides TECHNICAL SUPPORT
• UG-153: Evaluating the ±250°/Sec, Single Chip Rate Gyro Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS RATE SENSITIVE AXIS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION SETTING BANDWIDTH TEMPERATURE OUTPUT AND CALIBRATION MODIFYING THE ADXRS652 SCALE TO MATCH THE ADXRS620 CALIBRATED PERFORMANCE ADXRS652 AND SUPPLY RATIOMETRICITY NULL ADJUSTMENT SELF-TEST FUNCTION CONTINUOUS SELF-TEST OUTLINE DIMENSIONS ORDERING GUIDE
