Datasheet ADXRS652 (Analog Devices) - 7 Manufacturer Analog Devices Description ±250°/sec Yaw Rate Gyro Pages / Page 13 / 7 — ) 30. (% 16. L U 12. PUL 20. O P 10. O 15. E G. A T. N 10. E C. RCE. E P. … Revision A File Format / Size PDF / 356 Kb Document Language English
) 30. (% 16. L U 12. PUL 20. O P 10. O 15. E G. A T. N 10. E C. RCE. E P. –10. RATE OUT (V). PERCENT CHANGE FROM 25°C. % (. N (. N 30. IO 50. IO T A. LAT U. P 40
Model Line for this Datasheet Text Version of Document ADXRS652 TYPICAL PERFORMANCE CHARACTERISTICS N > 1000 for all typical performance plots, unless otherwise noted.20 35 18 ) ) 30 % (% 16 ( N N IO IO 14 25 T AT A L U 12 P PUL 20 O P 10 PO F F O O 15 E 8 E G AG A T NT 6 N 10 E C RCE 4 R E P PE 5 2 0 0 0 2 4 6 8 720 25 30 35 40 45 50 55 60 65 70 75 80 4–10 –8 –6 –4 –2 10 2. 2. 2. 2. 2. 2. 2. 2. 2. 2. 2. 2. 2. -00 -00 20RATE OUT (V) 820PERCENT CHANGE FROM 25°C 88 0 08 Figure 4. Null Output at 25°C (VRATIO = 5 V) Figure 7. Sensitivity Drift over Temperature70 40 ) 35 60 ) % % ( N ( N 30 IO 50 IO T A LAT U 25 P 40 PUL O P PO F 20 F O O 30 E E G 15 AG A T NT 20 N E CE 10 C R R E P 10 PE 5 0 0 0 0 0 0 0 0 0 0 50 –50 810 15 20 25 30 35 40 05675 650 625 600 575 550 525 500 475 450 425 400 –400 –350 –300 –250 –200 –150 –100 -0– – – – – – – – – – – – –375 -00 20 20mV DRIFT FROM 25°C 88ST1 Δ (mV) 88 0 0 Figure 5. Null Drift over Temperature (VRATIO = 5 V) Figure 8. ST1 Output Change at 25°C (VRATIO = 5 V)30 40 ) 35 ) 25 % (% ( N N 30 IO IO T T 20 25 PULA PULA PO 15 PO F 20 O OF E E G G A 15 A T 10 T EN EN C 10 C 5 ER PER P 5 0 0 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 060 5 0 5 6. 6. 6. 6. 6. 6. 6. 7. 7. 7. 7. 7. 7. 7. 7. 7. 0 9 0-375 400 425 450 475 500 525 550 575 60 62 65 67 -00(mV/°/sec) 82 20 08ST2 Δ (mV) 88 0 Figure 6. Sensitivity at 25°C (VRATIO = 5 V) Figure 9. ST2 Output Change at 25°C (VRATIO = 5 V) Rev. A | Page 6 of 12 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS RATE SENSITIVE AXIS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION SETTING BANDWIDTH TEMPERATURE OUTPUT AND CALIBRATION MODIFYING THE ADXRS652 SCALE TO MATCH THE ADXRS620 CALIBRATED PERFORMANCE ADXRS652 AND SUPPLY RATIOMETRICITY NULL ADJUSTMENT SELF-TEST FUNCTION CONTINUOUS SELF-TEST OUTLINE DIMENSIONS ORDERING GUIDE
