Datasheet ADXRS652 (Analog Devices) - 8
Description±250°/sec Yaw Rate Gyro
Pages / Page13 / 8 — ) 60. IO 50. T A. AT 20. L U. PUL 40. P O. N 20. E C R. RCE E. PERCENT …
File Format / SizePDF / 356 Kb
) 60. IO 50. T A. AT 20. L U. PUL 40. P O. N 20. E C R. RCE E. PERCENT MISMATCH (%). VOLTAGE (V). 600. 3.3. 3.1. 400. 2.9. ST2. ) 200. 2.7. (mV. E ( 2.5. EST. L 2.3
) 60 IO 50 T A AT 20 L U PUL 40 P O N 20 E C R RCE E PERCENT MISMATCH (%) VOLTAGE (V) 600 3.3 3.1 400 2.9 ST2 ) 200 2.7 (mV E ( 2.5 EST L 2.3
ADXRS652
70 30 ) 60 ) % 25 ( (% N N IO 50 IO T A AT 20 L U PUL 40 P O PO P F 15 F O O 30 E E G G A A T 10 N 20 NT E C R RCE E PE 5 10 P 0 0 0 1 2 3 4 5
0
–5 –4 –3 –2 –1 35 37 39 41 43 45 47 49 51 53 55
13 -01
2. 2. 2. 2. 2. 2. 2. 2. 2. 2. 2.
0 20
20- 88 0
VOLTAGE (V)
88 0 Figure 10. Self-Test Mismatch at 25°C (VRATIO = 5 V) Figure 13. VTEMP Output at 25°C (VRATIO = 5 V)
600 3.3 3.1 400 2.9 ST2 ) 200 2.7 ) (mV V Δ E ( 2.5 G 0 A EST T -T L 2.3 F VO 200 SEL 2.1 ST1 1.9 400 1.7 600 1.5
1 14
–50 –30 –10 10 30 50 70 90 110
1 -01
–50 –25 0 25 50 75 100
0- 20 82
TEMPERATURE (°C)
88
TEMPERATURE (°C)
0 08 Figure 11. Typical Self-Test Change over Temperature Figure 14. VTEMP Output over Temperature, 256 Parts (VRATIO = 5 V)
30 60 REF ) 50 Y % 25 X N ( IO 40 +45° 20 LAT –45° U 30 P c O e P /s 15 F ° 20 O E OR g AG 10 10 NT 0 RCE E P 5 –10 0 –20 5 7 9 1 3 5 7 9 1 3 5
2 1 14
2. 2. 2. 3. 3. 3. 3. 3. 4. 4. 4.
0
750 770 790 810 830 850
0 0- 0-
CURRENT CONSUMPTION (m A)
82
TIME (ms)
82 08 08 Figure 12. Current Consumption at 25°C (VRATIO = 5 V) Figure 15. g and g × g Sensitivity for a 50 g, 10 ms Pulse Rev. A | Page 7 of 12 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS RATE SENSITIVE AXIS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION SETTING BANDWIDTH TEMPERATURE OUTPUT AND CALIBRATION MODIFYING THE ADXRS652 SCALE TO MATCH THE ADXRS620 CALIBRATED PERFORMANCE ADXRS652 AND SUPPLY RATIOMETRICITY NULL ADJUSTMENT SELF-TEST FUNCTION CONTINUOUS SELF-TEST OUTLINE DIMENSIONS ORDERING GUIDE
