Datasheet ADXRS652 (Analog Devices) - 9 Manufacturer Analog Devices Description ±250°/sec Yaw Rate Gyro Pages / Page 13 / 9 — 2.0. 0.10. LAT. 1.8. LONG RATE. 1.6. ) c. 0.05. ) 1.4. s °/. °/s. T 1.2. … Revision A File Format / Size PDF / 356 Kb Document Language English
2.0. 0.10. LAT. 1.8. LONG RATE. 1.6. ) c. 0.05. ) 1.4. s °/. °/s. T 1.2. E 1.0. O R. 0.8. AK RA. E P 0.6. TE A –0.05. 0.4. 0.2. –0.10. 100. 10k. 120. 140. FREQUENCY (Hz)
Model Line for this Datasheet Text Version of Document ADXRS6522.0 0.10 LAT 1.8 LONG RATE 1.6 ) c 0.05 e ) 1.4 s °/ °/s ( ( N T 1.2 U O O TI E 1.0 T TA 0 O R 0.8 AK RA OF E P 0.6 TE A –0.05 R 0.4 0.2 0 –0.10 16 8100 1k 10k 10 20 40 60 80 100 120 140 01 0- 0-FREQUENCY (Hz) 82 82 08TIME (Hours) 08 Figure 16. Typical Response to 10 g Sinusoidal Vibration Figure 19. Typical Shift in 90 sec Null Averages Accumulated (Sensor Bandwidth = 40 Hz) over 140 Hours400 0.10 300 ) DUT1 OFFSET BY +200°/sec 200 0.05 °/sec ( °/sec) ( N 100 N IO IO T T A T 0 A T 0 RO RO F –100 F O O E E DUT2 OFFSET BY –200°/sec –200 RAT –0.05 RAT –300 –400 –0.10 0 50 100 150 200 250 16 00 600 1200 1800 2400 3000 3600 19 0 0- 0-TIME (ms) 82 82 08TIME (Seconds) 08 Figure 17. Typical High g (2500 g) Shock Response Figure 20. Typical Shift in Short Term Null (Bandwidth = 1 Hz) (Sensor Bandwidth = 40 Hz)1 0.1 ) s s) m m r r Hz °/sec 0.1 N ( °/sec/ 0.01 ( IO Y IT IAT S V N DE L AN DE A L 0.01 R L T 0.001 A C T E O P S RO E IS NO 0.001 0.01 0.1 1 10 100 1k 10k 100k 170.0001 0 0 0-10 100 1k 10k 100k 02AVERAGING TIME (Seconds) 0- 882 0FREQUENCY (Hz) 82 08 Figure 18. Typical Root Allan Deviation at 25°C vs. Averaging Time Figure 21. Typical Noise Spectral Density (Bandwidth = 40 Hz) Rev. A | Page 8 of 12 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS RATE SENSITIVE AXIS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION SETTING BANDWIDTH TEMPERATURE OUTPUT AND CALIBRATION MODIFYING THE ADXRS652 SCALE TO MATCH THE ADXRS620 CALIBRATED PERFORMANCE ADXRS652 AND SUPPLY RATIOMETRICITY NULL ADJUSTMENT SELF-TEST FUNCTION CONTINUOUS SELF-TEST OUTLINE DIMENSIONS ORDERING GUIDE
