Datasheet ADIS16080 (Analog Devices) - 9
Description | ±80°/sec Yaw Rate Gyro with SPI Interface |
Pages / Page | 17 / 9 — ADIS16080. TYPICAL PERFORMANCE CHARACTERISTICS. AVERAGE = 2014.38. … |
Revision | C |
File Format / Size | PDF / 579 Kb |
ADIS16080. TYPICAL PERFORMANCE CHARACTERISTICS. AVERAGE = 2014.38. AVERAGE = 6.4mA. STD. DEVIATION = 99.3236
ADIS16080 TYPICAL PERFORMANCE CHARACTERISTICS 25 70 AVERAGE = 2014.38 AVERAGE = 6.4mA STD. DEVIATION = 99.3236 STD. DEVIATION = 0.2mA 60 ) ) 20 % % ( N ( 50 IO ION T T A 15 LA UL U 40 P P O O P P F 30 O 10 OF T NT N E C 20 RCE R E E P 5 P 10 0 0
05
00 25 50 75 00 25 50 75 00 25 50 75 00 25 50 75 00
08 0 0 5-
5. 5. 5. 5. 6. 6. 6. 6. 7. 7. 7. 7. 8. 8. 8. 8. 9.
5- 04
NULL (LSB)
604
SUPPLY CURRENT (mA)
0 06 Figure 6. Initial Null Histogram Figure 9. Supply Current Histogram
2080 20 –40°C AVERAGE = –519.6 LSB STD. DEVIATION = 21.892 LSB 2070 18 ) 16 % 2060 ( ) 14 B ION T 2050 LS LA 12 L ( U E P V 2040 O E 10 P L L +25°C L OF 2030 8 U T N N E 6 C 2020 R E P 4 +85°C 2010 2 2000 0 4.7 4.8 4.9 5.0 5.1 5.2 5.3
6 9 -00
–600 –590 –580 –570 –560 –550 –540 –530 –520 –510 –500 –490 –480 –470 –460 –450
-00
V
45 45
CC (V)
60 0
ST1 (LSB)
60 0 Figure 7. Null Level vs. Supply Voltage Figure 10. Self-Test 1 Histogram
2080 25 30 PART AVERAGE, VCC = 4.75V AVERAGE = 522.47 LSB 30 PART AVERAGE, VCC = 5.00V STD. DEVIATION = 19.9086 LSB 2070 30 PART AVERAGE, VCC = 5.25V ) 20 % 2060 ( ) B ION S T 2050 L ( LA 15 L U E P V 2040 O P LE LL 2030 OF 10 U T N N E C 2020 R E P 5 2010 2000 0 –50 –30 –10 10 30 50 70 90 110
7
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0 -00
45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
-01
TEMPERATURE (°C)
45 45 60 0
ST2 (LSB)
60 0 Figure 8. Null Level vs. Temperature Figure 11. Self-Test 2 Histogram Rev. $ | Page 8 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION SUPPLY AND COMMON CONSIDERATIONS INCREASING MEASUREMENT RANGE SETTING BANDWIDTH SELF-TEST FUNCTION CONTINUOUS SELF-TEST RATE SENSITIVE AXIS BASIC OPERATION SERIAL PERIPHERAL INTERFACE (SPI) Control Register ADC Conversion Output Data Access Output Coding Examples APPLICATIONS INFORMATION ASSEMBLY INTERFACE BOARD OUTLINE DIMENSIONS ORDERING GUIDE
