Datasheet AD8452 (Analog Devices) - 7
DescriptionPrecision Integrated Analog Front End, Controller, and PWM for Battery Test and Formation Systems
Pages / Page35 / 7 — AD8452. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. …
File Format / SizePDF / 754 Kb
AD8452. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit. DIGITAL INTERFACE SPECIFICATIONS. Table 3. Parameter
AD8452 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit DIGITAL INTERFACE SPECIFICATIONS Table 3 Parameter
ZERO CROSSING DETECTION (ZCD) ZCD Threshold Offset (VCLP + VCLN)/2, for common-mode voltage 0 mV (CMV) = 0 V to 8 V VREG Low Dropout (LDO) Regulator Output VIN = 6 V to 60 V, no external load 4.9 5 5.1 V Voltage Load Regulation VIN = 6 V, IOUT = 0 mA to 5 mA 4.9 5 5.1 V PWM DRIVE LOGIC SIGNALS (DH/DL) DL Drive Voltage No load VREG V DH Drive Voltage No load VREG V DL and DH Sink Resistance IDL = 10 mA 1.4 2.6 Ω DL and DH Source Resistance IDL = 10 mA 1.4 2.6 Ω DL and DH Pull-Down Resistor 0.5 1 1.5 MΩ THERMAL SHUTDOWN (TSD) TSD Threshold Rising 150 °C Falling 125 °C 1 The DMAX and SCFG current matching specification is calculated by taking the absolute value of the difference between the measured ISCFG and IDMAX currents, dividing them by the 11 µA typical value, and multiplying this result by 100. DMAX and SCFG current matching (%) = (ISCFG – IDMAX/11 µA) × 100
DIGITAL INTERFACE SPECIFICATIONS Table 3. Parameter Test Conditions/Comments Min Typ Max Unit
DIGITAL INTERFACE, MODE INPUT MODE pin MODE Threshold Rising 1.2 1.4 V MODE Threshold Falling 0.7 1.0 V MODE Switching Time 400 ns PRECISION ENABLE LOGIC (EN) Maximum EN Pin Voltage 60 V EN Threshold Rising 1.26 1.4 V EN Threshold Falling 1.1 1.2 V EN Pin Current VEN = 5 V, internal pull-down 0.25 2 µA FAULT Active low input Maximum FAULT Pin Voltage 60 V FAULT Threshold Rising 1.2 1.5 V FAULT Threshold Falling 0.7 1.0 V FAULT Pin Current VFAULT = 5 V, internal 8.5 MΩ pull- 0.5 2 µA down resistor Rev. 0 | Page 6 of 34 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Analog Front-End and Controller Specifications Pulse-Width Modulator Specifications Digital Interface Specifications Power Supply Temperature Range Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics In-Amp Characteristics Difference Amplifier Characteristics CC and CV Loop Filter Amplifiers and VSET Buffer (except where Noted) Reference Characteristics Pulse-Width Modulator Theory of Operation Introduction Instrumentation Amplifier (In-Amp) Reversing Polarity When Charging and Discharging In-Amp Offset Option Battery Reversal and Overvoltage Protection Difference Amplifier CC and CV Loop Filter Amplifiers Charging Lithium-Ion (Li-Ion) Cells Concepts of Constant Current (CC) and Constant Voltage (CV) Compensation Charge and Discharge Control Conditions to Charge and Discharge a Battery MODE Pin Input and Output Supply Pins Shutdown Undervoltage Lockout (UVLO) Soft Start PWM Drive Signals Peak Current Protection and Diode Emulation (Synchronous) Peak Current-Limit Detection Diode Emulation/Synchronous Mode Operation Frequency and Phase Control Internal Frequency Control External Frequency Control Operating Frequency Phase Shift Maximum Duty Cycle Fault Input Thermal Shutdown (TSD) Applications Information Analog Controller Functional Description Power Supply Connections Current Sense In-Amp Connections Current Sensors Optional Low-Pass Filter Voltage Sense Differential Amplifier Connections Battery Current and Voltage Control Inputs (ISET and VSET) Loop Filter Amplifiers Selecting Charge or Discharge Options Select RCL and RCLVT for the Peak Current Limit Setting the Operating Frequency and Programming the Synchonization Pin Select RFREQ for Standalone or Master Clock Selecting RFREQ for a Slave Device Programming the External Clock Phase Shift Programming the Dead Time Programming the Maximum Duty Cycle Selecting CSS Additional Information Outline Dimensions Ordering Guide
