Datasheet AD8452 (Analog Devices) - 8
DescriptionPrecision Integrated Analog Front End, Controller, and PWM for Battery Test and Formation Systems
Pages / Page35 / 8 — Data Sheet. AD8452. POWER SUPPLY. Table 4. Parameter. Test …
File Format / SizePDF / 754 Kb
Data Sheet. AD8452. POWER SUPPLY. Table 4. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit. TEMPERATURE RANGE SPECIFICATIONS
Data Sheet AD8452 POWER SUPPLY Table 4 Parameter Test Conditions/Comments Min Typ Max Unit TEMPERATURE RANGE SPECIFICATIONS
Data Sheet AD8452 POWER SUPPLY Table 4. Parameter Test Conditions/Comments Min Typ Max Unit
ANALOG POWER SUPPLY Operating Voltage Range AVCC 10 36 V AVEE −26 0 V Analog Supply Range AVCC − AVEE 10 36 V Quiescent Current AVCC 4.7 6.5 mA AVEE 4.4 6.0 mA PWM POWER SUPPLY (VIN) VIN Voltage Range 6 60 V VIN Supply Current RFREQ = 100 kΩ, VSS = 0 V, SYNC = open 2.2 3.0 mA circuit (OC), FAULT = low, EN = high UVLO Threshold Rising VIN rising 5.75 6 V UVLO Threshold Falling VIN falling 5.1 5.34 V
TEMPERATURE RANGE SPECIFICATIONS Table 5. Parameter Min Typ Max Unit
TEMPERATURE RANGE For Specified Performance −40 +85 °C Operational −55 +125 °C Rev. 0 | Page 7 of 34 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Analog Front-End and Controller Specifications Pulse-Width Modulator Specifications Digital Interface Specifications Power Supply Temperature Range Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics In-Amp Characteristics Difference Amplifier Characteristics CC and CV Loop Filter Amplifiers and VSET Buffer (except where Noted) Reference Characteristics Pulse-Width Modulator Theory of Operation Introduction Instrumentation Amplifier (In-Amp) Reversing Polarity When Charging and Discharging In-Amp Offset Option Battery Reversal and Overvoltage Protection Difference Amplifier CC and CV Loop Filter Amplifiers Charging Lithium-Ion (Li-Ion) Cells Concepts of Constant Current (CC) and Constant Voltage (CV) Compensation Charge and Discharge Control Conditions to Charge and Discharge a Battery MODE Pin Input and Output Supply Pins Shutdown Undervoltage Lockout (UVLO) Soft Start PWM Drive Signals Peak Current Protection and Diode Emulation (Synchronous) Peak Current-Limit Detection Diode Emulation/Synchronous Mode Operation Frequency and Phase Control Internal Frequency Control External Frequency Control Operating Frequency Phase Shift Maximum Duty Cycle Fault Input Thermal Shutdown (TSD) Applications Information Analog Controller Functional Description Power Supply Connections Current Sense In-Amp Connections Current Sensors Optional Low-Pass Filter Voltage Sense Differential Amplifier Connections Battery Current and Voltage Control Inputs (ISET and VSET) Loop Filter Amplifiers Selecting Charge or Discharge Options Select RCL and RCLVT for the Peak Current Limit Setting the Operating Frequency and Programming the Synchonization Pin Select RFREQ for Standalone or Master Clock Selecting RFREQ for a Slave Device Programming the External Clock Phase Shift Programming the Dead Time Programming the Maximum Duty Cycle Selecting CSS Additional Information Outline Dimensions Ordering Guide
