Datasheet AD8037 (Analog Devices) - 3
DescriptionLow Distortion, Wide Bandwidth Voltage Feedback Clamp Amps
Pages / Page13 / 3 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/16612
File Format / SizePDF / 149 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/16612
1.3 Absolute maximum ratings. 1/ Supply voltage (VS) .. 12.6 V Power dissipation (PD) ... See figure 3 Voltage swing x bandwidth product .. 350 V- MHz Common mode input voltage ... VS |High clamping voltage (VH) – Input voltage (VIN)| ...  6.3 V |Low clamping voltage (VL) – VIN| ..  6.3 V Differential input voltage ... 1.2 V Storage temperature range (TSTG) .. -65C to +125C Lead temperature (soldering, 10 seconds) ... +300C Junction temperature range (TJ) .. +150C 2/ Thermal resistance, junction to ambient (JA) .. 155C/W 1.4 Recommended operating conditions. 3/ Supply voltage range (VS) .. 5 V Operating free-air temperature range (TA) ... -55C to +105C 1/ Stresses beyond those listed under “absolute maximum rating” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. 2/ Exceeding a junction temperature of +175C for an extended period can result in device failure. 3/ Use of this product beyond the manufacturers design rules or stated parameters is done at the user’s risk. The manufacturer and/or distributor maintain no responsibility or liability for product used beyond the stated limits.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/16612
REV PAGE 3
