Datasheet AD8037 (Analog Devices) - 4
DescriptionLow Distortion, Wide Bandwidth Voltage Feedback Clamp Amps
Pages / Page13 / 4 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/16612
File Format / SizePDF / 149 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/16612
2. APPLICABLE DOCUMENTS JEDEC Solid State Technology Association JEDEC PUB 95 – Registered and Standard Outlines for Semiconductor Devices (Copies of these documents are available online at http:/www.jedec.org or from JEDEC – Solid State Technology Association, 3103 North 10th Street, Suite 240–S, Arlington, VA 22201-2107). 3. REQUIREMENTS 3.1 Marking. Parts shall be permanently and legibly marked with the manufacturer’s part number as shown in 6.3 herein and as follows: A. Manufacturer’s name, CAGE code, or logo B. Pin 1 identifier C. ESDS identification (optional) 3.2 Unit container. The unit container shall be marked with the manufacturer’s part number and with items A and C (if applicable) above. 3.3 Electrical characteristics. The maximum and recommended operating conditions and electrical performance characteristics are as specified in 1.3, 1.4, and table I herein. 3.4 Design, construction, and physical dimension. The design, construction, and physical dimensions are as specified herein. 3.5 Diagrams. 3.5.1 Case outline. The case outline shall be as shown in 1.2.2 and figure 1. 3.5.2 Terminal connections. The terminal connections shall be as shown in figure 2. 3.5.3 Power dissipation graph. The power dissipation graph shall be as shown in figure 3.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/16612
REV PAGE 4
