Datasheet AD8037 (Analog Devices) - 5
Description | Low Distortion, Wide Bandwidth Voltage Feedback Clamp Amps |
Pages / Page | 13 / 5 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/16612 |
File Format / Size | PDF / 149 Kb |
TABLE I. Electrical performance characteristics. 1/ Test Symbol Conditions 2/ Temperature, Device Limits Unit TA type Min Max Dynamic performance. Small signal bandwidth VOUT 0.4 Vp-p +25C 01 200 MHz at -3 dB 270 typical Large signal 3/ VOUT = 3.5 Vp-p +25C 01 160 MHz bandwidth at -3 dB 190 typical Bandwidth for 0.1 dB VOUT 0.4 Vp-p, RF = 274 +25C 01 130 typical MHz flatness Slew rate, average VOUT = 4 V step, 10% to 90% +25C 01 1100 V/s 1500 typical Rise/fall time VOUT = 0.5 V step, 10% to 90% +25C 01 1.2 typical ns VOUT = 4 V step, 10% to 90% 2.2 typical Settling time to 0.1% VOUT = 2 V step +25C 01 10 typical ns Settling time to 0.01% VOUT = 2 V step +25C 01 16 typical ns Noise/harmonic performance. Second harmonic 2 Vpp, 20 MHz, RL = 100 +25C 01 -45 dBc distortion -52 typical 2 Vpp, 20 MHz, RL = 500 +25C -65 -72 typical Third harmonic 2 Vpp, 20 MHz, RL = 100 +25C 01 -63 dBc distortion -70 typical 2 Vpp, 20 MHz, RL = 500 +25C -73 -80 typical See footnotes at end of table.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/16612
REV PAGE 5
