Datasheet AD822-EP (Analog Devices) - 7
DescriptionSingle-Supply, Rail-to-Rail Low Power FET-Input Op Amp
Pages / Page20 / 7 — AD822-EP. Grade. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
File Format / SizePDF / 321 Kb
AD822-EP Grade Parameter Test Conditions/Comments Min Typ Max Unit
link to page 7
AD822-EP T Grade Parameter Test Conditions/Comments Min Typ Max Unit
OUTPUT CHARACTERISTICS Output Saturation Voltage2 VOL − VEE ISINK = 20 μA 5 7 mV TMIN to TMAX 10 mV VCC − VOH ISOURCE = 20 μA 10 14 mV TMIN to TMAX 20 mV VOL − VEE ISINK = 2 mA 40 55 mV TMIN to TMAX 80 mV VCC − VOH ISOURCE = 2 mA 80 110 mV TMIN to TMAX 160 mV VOL − VEE ISINK = 15 mA 300 500 mV TMIN to TMAX 1000 mV VCC − VOH ISOURCE = 15 mA 800 1500 mV TMIN to TMAX 1900 mV Operating Output Current 15 mA TMIN to TMAX 12 mA Capacitive Load Drive 350 pF POWER SUPPLY Quiescent Current, TMIN to TMAX 1.3 1.6 mA Power Supply Rejection VSY = ±5 V to ±15 V 66 80 dB TMIN to TMAX 66 dB 1 This is a functional specification. Amplifier bandwidth decreases when the input common-mode voltage is driven in the range (V+ − 1 V) to V+. Common-mode error voltage is typically less than 5 mV with the common-mode voltage set at 1 V below the positive supply. 2 VOL − VEE is defined as the difference between the lowest possible output voltage (VOL) and the negative voltage supply rail (VEE). VCC − VOH is defined as the difference between the highest possible output voltage (VOH) and the positive supply voltage (VCC). Rev. 0 | Page 7 of 20 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
