Datasheet AD845 (Analog Devices) - 2
DescriptionPrecision, 16 MHz CBFET Op Amp
Pages / Page9 / 2 — STANDARD. 5962-89645. MICROCIRCUIT DRAWING
File Format / SizePDF / 92 Kb
STANDARD 5962-89645 MICROCIRCUIT DRAWING
1. SCOPE 1.1 Scope. This drawing describes device requirements for MIL-STD-883 compliant, non-JAN class level B microcircuits in accordance with MIL-PRF-38535, appendix A. 1.2 Part or Identifying Number (PIN). The complete PIN is as shown in the following example: 5962-89645 01 P A Drawing number Device type Case outline Lead finish (see 1.2.1) (see 1.2.2) (see 1.2.3) 1.2.1 Device type(s). The device type(s) identify the circuit function as follows: Device type Generic number Circuit function 01 AD845 Operational amplifier 1.2.2 Case outline(s). The case outline(s) are as designated in MIL-STD-1835 and as follows: Outline letter Descriptive designator Terminals Package style P GDIP1-T8 or CDIP2-T8 8 Dual-in-line 1.2.3 Lead finish. The lead finish is as specified in MIL-PRF-38535, appendix A. 1.3 Absolute maximum ratings. 1/ Supply voltage (±VS) ... ±18 V Common-mode input voltage .. ±VS Output short circuit duration .. Indefinite Differential input voltage .. +VS and –VS Internal power dissipation (PD) ... 1.3 W 2/ Junction temperature (TJ) ... +175°C Lead temperature (soldering, 60 seconds) .. +300°C Storage temperature range ... -65°C to +150°C Thermal resistance, junction-to-case (θJC) ... +30°C/W Thermal resistance, junction-to-ambient (θJA) .. +110°C/W 1.4 Recommended operating conditions. Positive supply voltage (+VS) .. +15 V Negative supply voltage (-VS) ... -15 V Ambient operating temperature range (TA) ... -55°C to +125°C 1/ Stresses above the absolute maximum rating may cause permanent damage to the device. Extended operation at the maximum levels may degrade performance and affect reliability. 2/ Maximum internal power dissipation is specified so that TJ does not exceed +175°C at an ambient temperature of +25°C. Derate P package at 8.7 mW/°C above TA = +25°C.
STANDARD
SIZE
A 5962-89645 MICROCIRCUIT DRAWING
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 C
2
DSCC FORM 2234 APR 97
