Datasheet HMC905LP3E (Analog Devices) - 3
Description6 GHz Low Noise Programmable Divider (N = 1 - 4)
Pages / Page10 / 3 — HMC905LP3E. 6 GHz LOW NOISE PROGRAMMABLE. DIVIDER (N = 1 to 4). Output …
File Format / SizePDF / 675 Kb
HMC905LP3E. 6 GHz LOW NOISE PROGRAMMABLE. DIVIDER (N = 1 to 4). Output Power vs. Temperature. Pout vs. Division Ratio
HMC905LP3E 6 GHz LOW NOISE PROGRAMMABLE DIVIDER (N = 1 to 4) Output Power vs Temperature Pout vs Division Ratio
HMC905LP3E
v01.0414
6 GHz LOW NOISE PROGRAMMABLE DIVIDER (N = 1 to 4) Output Power vs. Temperature Pout vs. Division Ratio Divide-by-4
4 10 10 CTRL=1, BIAS1BIAS0=01 CTRL=1, BIAS1BIAS0=01->101 CTRL=0, BIAS1BIAS0=00->000 4 5 5 T (dBm) (dBm) T M 0 0 POWER POWER M +25°C 101 Div by 4 +85°C 101 -5 Div by 3 -5 -40°C 101 S - S OUTPUT Div by 2 OUTPUT +25°C 000 Div by 1 +85°C 000 -40°C 000 S - S R -10 -10 R O 0 1 2 3 4 5 6 7 8 0 1 2 3 4 5 6 7 8 INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz) O T T C C E E T
Output Power vs. Input Power Level
T E
Divide-by-4 Pout Divide-by-4 vs. CTRL & BIAS
E 10 10 CTRL=1, BIAS1BIAS0=01 S & D 5 5 (dBm) (dBm) S & D R R E 0 POWER 0 POWER E ID CTRL=0, BIAS=00 ID IV 6dBm -5 CTRL=1,BIAS=00 OUTPUT 3dBm -5 OUTPUT CTRL=0,BIAS=01 9dBm IV CTRL=1,BIAS=01 Y D -10 -10 0 1 2 3 4 5 6 7 8 0 1 2 3 4 5 6 7 8 Y D C INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz) C N N E E U
Output Power vs. Voltage Supply
U Q
Divide-by-4
Q E 10 E R CTRL=1, BIAS1BIAS0=01 R F 5 F (dBm) 0 POWER 3.3V -5 OUTPUT 3.15V 3.45V -10 0 1 2 3 4 5 6 7 8 INPUT FREQUENCY (GHz) [1] CTRL = 0, BIAS1, BIAS1 BIAS0 = 00, Pin = 6 dBm Info F rmoatr p ion rfiurcne is , d hed ebly ivAe n r al y a og D n evd t ice o p s is bla eli c eve o ed t rd o b e e ras: H ccuratite tiatne M d reli iac bl reo . w Ho av wev e C er, n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
4 - 3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
