Datasheet HMC905LP3E (Analog Devices) - 5
Description6 GHz Low Noise Programmable Divider (N = 1 - 4)
Pages / Page10 / 5 — HMC905LP3E. 6 GHz LOW NOISE PROGRAMMABLE. DIVIDER (N = 1 to 4). …
File Format / SizePDF / 675 Kb
HMC905LP3E. 6 GHz LOW NOISE PROGRAMMABLE. DIVIDER (N = 1 to 4). Programming Truth Table. Absolute Maximum Ratings
HMC905LP3E 6 GHz LOW NOISE PROGRAMMABLE DIVIDER (N = 1 to 4) Programming Truth Table Absolute Maximum Ratings
HMC905LP3E
v01.0414
6 GHz LOW NOISE PROGRAMMABLE DIVIDER (N = 1 to 4) Programming Truth Table Absolute Maximum Ratings for Frequency Division Ratios
4 RF Input Power 12 dBm B1 B0 Divide-by Supply Voltage (Vcc) 3.6V 0 0 1 4 Control Inputs 0 1 2 3.6V T (B0, B1, CTRL, Bias0, EN) 1 0 3 Junction Temperature 125 °C T M 1 1 4 Continuous Pdiss (T = 85 °C) M 1.3 W 0 = Logic Low (derate 33 mW/ °C above 85 °C) 1 = Logic High Thermal Resistance S - S 30 °C/W (Junction to ground paddle)
Digital Control Input Voltages
Storage Temperature -65 to +125 °C S - S R State B0, B1, CTRL, BIAS1, BIAS0, EN R O Operating Temperature -40 to +85 °C ESD Sensitivity (HBM) Class 1A Low 0 to 0.8V O T High 1.5V to 3.3V T C C E ELECTROSTATIC SENSITIVE DEVICE E T OBSERVE HANDLING PRECAUTIONS T E E
Typical Supply Current vs. EN, BIAS0, BIAS1 & CTRL Bits
S & D 3.3V Supply Typ. Pout Typ. EN CTRL BIAS1 BIAS0 Noise Floor S & D R Current (mA) (dBm) R E 1 0 0 0 84 1.5 Low E ID 1 0 0 1 105 4.8 ID IV 1 0 1 0 98 3.9 1 1 0 0 100 2.4 Better IV Y D 1 1 0 1 120 6.3 Best 1 1 1 0 113 5.3 Y D C 0 x x x 0.001 -55 C N Note: Currents for the divide-by-4 option, 2 GHz and 6 dBm input and 3.3V; for Vcc voltage supply from N E 3.15V to 3.45V, the HMC905LP3E total current is varying with a maximum of ~8% around typical values. E U With temperature, the total current is changing from +25°C to -40°C/+85°C with about ±3%. U Q Q E E R R F F Info F rmoatr p ion rfiurcne is , d hed ebly ivAe n r al y a og D n evd t ice o p s is bla eli c eve o ed t rd o b e e ras: H ccuratite tiatne M d reli iac bl reo . w Ho av wev e C er, n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
4 - 5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
