Datasheet HMC905LP3E (Analog Devices) - 6
Description6 GHz Low Noise Programmable Divider (N = 1 - 4)
Pages / Page10 / 6 — HMC905LP3E. 6 GHz LOW NOISE PROGRAMMABLE. DIVIDER (N = 1 to 4). Outline …
File Format / SizePDF / 675 Kb
HMC905LP3E. 6 GHz LOW NOISE PROGRAMMABLE. DIVIDER (N = 1 to 4). Outline Drawing. Package Information. 4 - 6
HMC905LP3E 6 GHz LOW NOISE PROGRAMMABLE DIVIDER (N = 1 to 4) Outline Drawing Package Information 4 - 6
HMC905LP3E
v01.0414
4 4 T T M M S - S S - S R R O O T T C C E E T T E E NOTES: 1. LEADFRAME MATERIAL: COPPER ALLOY 2. DIMENSIONS ARE IN INCHES [MILLIMETERS]. S & D 3. LEAD SPACING TOLERANCE IS NON-CUMULATIVE 4. PAD BURR LENGTH SHALL BE 0.15mm MAXIMUM. S & D R PAD BURR HEIGHT SHALL BE 0.05mm MAXIMUM. R E 5. PACKAGE WARP SHALL NOT EXCEED 0.05mm. 6. ALL GROUND LEADS AND GROUND PADDLE MUST E ID BE SOLDERED TO PCB RF GROUND. ID IV 7. REFER TO HITTITE APPLICATION NOTE FOR SUGGESTED PCB LAND PATTERN. IV
Package Information
Y D Part Number Package Body Material Lead Finish MSL Rating Package Marking [1] Y D C HMC905LP3E RoHS-compliant Low Stress Injection Molded Plastic 100% matte Sn MSL1 [2] 905 XXX C N [1] 4-Digit lot number XXXX N E [2] Max peak reflow temperature of 260 °C E U U Q Q E E R R F F Info F rmoatr p ion rfiurcne is , d hed ebly ivAe n r al y a og D n evd t ice o p s is bla eli c eve o ed t rd o b e e ras: H ccuratite tiatne M d reli iac bl reo . w Ho av wev e C er, n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
4 - 6
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
