Datasheet HMC905LP3E (Analog Devices) - 7
Description6 GHz Low Noise Programmable Divider (N = 1 - 4)
Pages / Page10 / 7 — HMC905LP3E. 6 GHz LOW NOISE PROGRAMMABLE. DIVIDER (N = 1 to 4). Pin …
File Format / SizePDF / 675 Kb
HMC905LP3E. 6 GHz LOW NOISE PROGRAMMABLE. DIVIDER (N = 1 to 4). Pin Description. 4 - 7
HMC905LP3E 6 GHz LOW NOISE PROGRAMMABLE DIVIDER (N = 1 to 4) Pin Description 4 - 7
HMC905LP3E
v01.0414
4 Pin Number Function Description Interface Schematic 4 T 1 Vcc +3.3V Voltage Supply T M M S - S S - S R R O RF Positive Input. 2 RFINP Input is DC coupled, external DC blocks required. O T T C C E E T T E E S & D RF Negative Input. 3 RFINN Input is DC coupled, external DC blocks required. S & D R R E E ID ID IV IV 4 GND This pin must be connected to RF/DC ground. Y D Y D C Division ratio (LSB) 5 B0 See programming truth table. C N N E Division ratio (MSB) 6 B1 E U See programming truth table. U Q 7 CTRL Divider Output Buffer Power Control Q E E R R F 13 BIAS1 Divider Core Bias Control F 14 BIAS0 Divider Core Bias Control 15 EN Chip Enable No connection required. This pin may be 8, 9, 12, 16 N/C connected to ground, without affecting performance. Info F rmoatr p ion rfiurcne is , d hed ebly ivAe n r al y a og D n evd t ice o p s is bla eli c eve o ed t rd o b e e ras: H ccuratite tiatne M d reli iac bl reo . w Ho av wev e C er, n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
4 - 7
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
