Datasheet HMC794LP3E (Analog Devices) - 9
Description2 GHz Low Noise Programmable Divider (N = 1 to 4)
Pages / Page10 / 9 — HMC794LP3E. 2 GHz LOW NOISE PROGRAMMABLE. DIVIDER (N = 1 to 4). …
File Format / SizePDF / 788 Kb
HMC794LP3E. 2 GHz LOW NOISE PROGRAMMABLE. DIVIDER (N = 1 to 4). Evaluation PCB. List of Materials for Evaluation PCB 124842 [1]
HMC794LP3E 2 GHz LOW NOISE PROGRAMMABLE DIVIDER (N = 1 to 4) Evaluation PCB List of Materials for Evaluation PCB 124842 [1]
HMC794LP3E
v01.0612
t M s s - r o t c e t e s & D r e iD iv y D c n e u
q item Description item Description e J3 Dc connectors t6, t7 4:1 rF transformer, MABAct0065 r tP1, tP3, tP4 Pc compact sMt F J7, J8 sMA-F Johnson connector c1, c2, c4, c6, FB1, FB2 Murata BLM21AG02sniD 1 nF capacitor, 0402 Pkg. c10, c11 c12, c18 u1 HMc794LP3e Programmable Divider c3, c9, c14, c30, 0.1 µF capacitor, 0402 Pkg. u9 Hittite ultra Low noise quad regulator c31, c33, c34, c36 PcB [2] 124709 eval Board c5 10 µF capacitor, 1206 Pkg. [1] reference this number when ordering complete evaluation PcB c7 10,000 pF capacitor, 0402 Pkg. [2] circuit Board Material: rogers 4350 or Arlon 25Fr c8 10 pF capacitor, 0402 Pkg. c15, c35, c37, 4.7 µF capacitor, 0805 Pkg. the circuit board used in the application should use c68, c69, c72, c74 rF circuit design techniques. signal lines should have c32 1 µF capacitor, 0603 Pkg. 50 ohm impedance while the package ground leads r1, r7 100 ohm, resistor, 0402 Pkg. and backside ground paddle should be connected r2 - r6, r9 100 kohm, resistor, 0402 Pkg. directly to the ground plane similar to that shown. A r8, L2 0 ohm, resistor, 0402 Pkg. sufficient number of via holes should be used to con- r47 27 k ohm, resistor, 0402 Pkg. nect the top and bottom ground planes. the evalua- r48 15 k ohm, resistor, 0402 Pkg. tion circuit board shown is available from Hittite upon request. I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
9
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
