HMC794LP3E v01.0612 2 GHz LOW NOISE PROGRAMMABLEDIVIDER (N = 1 to 4)Electrical Specifications, T = +25° C, Vcc = +5V, ZAo = 50Ω, Bias1 = GND (Continued) Parameter conditions Min. typ. Max. units Power Supplies t vcc Analog supply 4.75 5 5.25 v M Current Consumption s itot - total current consumption 5v supply 100 150 mA 5v supply, ctrL = 0v, BiAs0 = 0v 100 130 mA itot - total current consumption [1] ctrL = 0v, BiAs0 = 5v 109 150 mA s - ctrL = 5v, BiAs0 = 0v 115 150 mA r sleep current en = 0v 1 µA o cBias reference voltage [2] Measured with 10 GΩ volt meter 3.8 v t [1] Bias0 = 0v, for maximum frequency range; Bias0 = 5v, for better phase noise floor; ctrL = 5v, for maximum output power c [2] cBias voltage pin cannot drive external load. it must be measured with a 10 GΩ volt meter such as Agilent 34410A, typical 10 Mohms DvM e will read erroneously. t e Residual Phase NoiseInput Sensitivity WindowDivide by 1, 2, 3 & 4, (Differential) [3] 20 -120 s & D 15 -130 Div By 1 Div By 2 r Div By 3 e 10 -140 Div By 4 (dBm) (dBc/Hz) iD 5 Recommended -150 Operating Window NOISE iv POWER 0 -160 PHASE INPUT -5 -170 y D SSB c -10 -180 0 0.5 1 1.5 2 2.5 101 102 103 104 105 106 107 n INPUT FREQUENCY (GHz) OFFSET FREQUENCY (Hz) e u q e Pout vs. Div Ratio [4], (Single-Ended)Pout vs. Div Ratio [4], (Differential) r 15 15 F 10 10 (dBm) 5 (dBm) 5 POWER 0 POWER 0 Div by 1 Div by 1 Div by 2 Div by 2 Div by 3 Div by 3 -5 OUTPUT -5 Div by 4 Div by 4 OUTPUT -10 -10 0 0.5 1 1.5 2 2.5 3 0 0.5 1 1.5 2 2.5 3 INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz) [3] ctrL = +5v, Bias0 = 0v, Pin = +8 dBm @ 2 GHz [4] ctrL = +5v, Bias0 = 0v, Pin = +4 dBm I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com 2 Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
