Datasheet HMC794LP3E (Analog Devices) - 3
Description2 GHz Low Noise Programmable Divider (N = 1 to 4)
Pages / Page10 / 3 — HMC794LP3E. 2 GHz LOW NOISE PROGRAMMABLE. DIVIDER (N = 1 to 4). Pout …
File Format / SizePDF / 788 Kb
HMC794LP3E. 2 GHz LOW NOISE PROGRAMMABLE. DIVIDER (N = 1 to 4). Pout Divide-by-1 vs. Temperature [1],
HMC794LP3E 2 GHz LOW NOISE PROGRAMMABLE DIVIDER (N = 1 to 4) Pout Divide-by-1 vs Temperature [1],
HMC794LP3E
v01.0612
2 GHz LOW NOISE PROGRAMMABLE DIVIDER (N = 1 to 4) Pout Divide-by-1 vs. Temperature [1], Pout Divide-by-2 vs. Temperature [1], (Single-Ended) (Single-Ended)
10 10 t M 5 5 s (dBm) (dBm) 0 0 s - POWER +25°C -5 POWER -5 +85°C r -40°C o +25°C -10 OUTPUT +85°C -10 OUTPUT t -40°C c -15 -15 e 0 0.5 1 1.5 2 2.5 3 0 0.5 1 1.5 2 2.5 3 INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz) t e
Pout Divide-by-3 vs. Temperature [1], Pout Divide-by-4 vs. Temperature [1], (Single-Ended) (Single-Ended)
s & D 10 10 r e 5 5 iD (dBm) 0 (dBm) 0 iv +25°C POWER +25°C -5 POWER +85°C -5 +85°C -40°C -40°C y D -10 -10 c OUTPUT OUTPUT n -15 -15 e 0 0.5 1 1.5 2 2.5 3 0 0.5 1 1.5 2 2.5 3 u INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz) q e
Pout Divide-by-3 vs. CTRL & Bias0 [2] Pout Divide-by-4 vs. CTRL & Bias0 [2]
r F
(Single-Ended) (Differential)
10 15 10 5 5 (dBm) (dBm) 0 CTRL = 0V, BIAS0= 0V 0 CTRL = 5V, BIAS0 = 0V CTRL = 0V, BIAS0 = 0V POWER -5 CTRL = 0V, BIAS0 = 5V POWER CTRL = 5V, BIAS0 = 0V -5 CTRL = 0V, BIAS0 = 5V -10 OUTPUT OUTPUT -10 -15 -15 0 0.5 1 1.5 2 2.5 3 0 0.5 1 1.5 2 2.5 3 INPUT FREQUENCY (GHz) INPUT FREQUENCY (GHz) [1] ctrL = 0v, Bias0 = 0v, Pin = +4 dBm [2] Pin = +4 dBm I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
