link to page 9 link to page 12 Data SheetADuM5010PIN CONFIGURATION AND FUNCTION DESCRIPTIONSNC120 NCGNDP 219 GNDISONC318 NCNC417 NCADuM5010GND516PGNDISOTOP VIEWGND615P(Not to Scale)GNDISONC714 NCPDIS 813 VSELV912DDPVISOGND1011PGNDISONOTES 1. PINS LABELED NC CAN BE ALLOWED TO FLOAT, BUT IT IS BETTER TO CONNECT THESE PINS TO GROUND. AVOID ROUTING HIGH SPEED SIGNALS 003 THROUGH THESE PINS BECAUSE NOISE COUPLING MAY RESULT. 10978- Figure 3. Pin Configuration Table 15. Pin Function Descriptions Pin No.Mnemonic Description 1, 3, 4, 7, 14, NC This pin is not connected internally (see Figure 3). 17, 18, 20 2, 5, 6, 10 GNDP Ground 1. Ground reference for isolator primary. Pin 2 and Pin 10 are internal y connected, and it is recommended that all pins be connected to a common ground. 8 PDIS Power Disable. When this pin is tied to GNDP the power converter is active; when a logic high voltage is applied, the power supply enters a low power standby mode. 9 VDDP Primary Supply Voltage, 3.0 V to 5.5 V. 11, 15, 16, 19 GNDISO Ground Reference for Isolator Side 2. Pin 19 and Pin 11 are internally connected, and it is recommended that all pins be connected to a common ground. 12 VISO Secondary Supply Voltage Output for External Loads, 3.15 V to 5.5 V depending on voltage divider connected to VSEL. 13 VSEL Output Voltage select input. A voltage divider attached to this pin between VISO and GNDISO determines the value of VISO, see Equation 1. TRUTH TABLETable 16. Truth Table (Positive Logic) VDDP (V)VSEL InputPDIS InputVISO Output (V)Notes 5 R1 = 10 kΩ, R2 = 30.9 kΩ Low 5 5 R1 = 10 kΩ, R2 = 30.9 kΩ High 0 3.3 R1 = 10 kΩ, R2 = 16.9 kΩ Low 3.3 3.3 R1 = 10 kΩ, R2 = 16.9 kΩ High 0 5 R1 = 10 kΩ, R2 = 16.9 kΩ Low 3.3 5 R1 = 10 kΩ, R2 = 16.9 kΩ High 0 3.3 R1 = 10 kΩ, R2 = 30.9 kΩ Low 5 Configuration not recommended 3.3 R1 = 10 kΩ, R2 = 30.9 kΩ High 0 Rev. A | Page 9 of 16 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Electrical Characteristics—5 V Primary Input Supply/5 V Secondary Isolated Supply Electrical Characteristics—3.3 V Primary Input Supply/3.3 V Secondary Isolated Supply Electrical Characteristics—5 V Primary Input Supply/3.3 V Secondary Isolated Supply Package Characteristics Regulatory Approvals Insulation and Safety-Related Specifications DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Truth Table Typical Performance Characteristics Applications Information PCB Layout Thermal Analysis EMI Considerations Insulation Lifetime Outline Dimensions Ordering Guide
