Datasheet LT6654 (Analog Devices) - 9
DescriptionPrecision Wide Supply High Output Drive Low Noise Reference
Pages / Page22 / 9 — Typical. perForMance characTerisTics The characteristic curves are …
Typical. perForMance characTerisTics The characteristic curves are similar across the
Typical perForMance characTerisTics The characteristic curves are similar across the
LT6654
LT6654
Typical perForMance characTerisTics The characteristic curves are similar across the LT6654 family. Curves from the LT6654-1.25, LT6654-2.5 and the LT6654-5 represent the full range of typical performance of all voltage options. Characteristic curves for other output voltages fall between these curves and can be estimated based on their output. 2.5V Integrated Noise 2.5V Power Supply Rejection 2.5V Output Impedance 10Hz to 10kHz Ratio vs Frequency vs Frequency
100 –20 100 –30 ) TIO (dB) –40 V RMS 10 CL = 1µF 10 –50 –60 TED NOISE (µ Y REJECTION RA C –70 L = 1µF 1 CL = 10µF 1 C –80 OUTPUT IMPEDANCE (Ω) L = 10µF INTEGRA –90 POWER SUPPL 0.1 –100 0.1 0.01 0.1 1 10 0.1 1 10 100 1000 1 10 100 1000 FREQUENCY (kHz) FREQUENCY (kHz) FREQUENCY (kHz) 6654 G19 6654 G20 6654 G21
2.5V Load Transient Response 2.5V Turn-On Characteristics 2.5V Line Transient Response (Sourcing)
VIN 0.5V/DIV IOUT 3V/DC 0mA VIN 1V/DIV 5mA GND VOUT VOUT V 2mV/DIV/AC OUT 20mV/DIV/AC 1V/DIV 2.5V/DC 2.5V/DC GND 20µs/DIV 6654 G22 50µs/DIV 6654 G23 50µs/DIV 6654 G24 CLOAD = 1µF CLOAD = 1µF CLOAD = 1µF
2.5V Hysteresis Plot for –40°C 2.5V Hysteresis Plot for –40°C and 125°C (TSOT-23) 2.5V Long Term Drift (TSOT-23) and 125°C (LS8)
48 MAX AVG HOT CYCLE 6 MAX AVG COLD CYCLE 150 T 44 A = 35°C 25°C TO –40°C TO 25°C 25°C TO 125°C TO 25°C 25°C TO –40°C TO 25°C 120 AND 25°C TO 125°C TO 25°C 40 5 90 36 32 60 4 28 30 24 0 3 20 TAGE CHANGE (ppm) –30 NUMBER OF UNITS 16 –60 NUMBER OF UNITS 2 12 8 –90 OUTPUT VOL 1 4 –120 0 –150 0 –150–125–100–75–50 –25 0 25 50 75 100125 150 0 400 800 1200 1600 2000 –40 –30 –20 –10 0 10 20 30 40 DISTRIBUTION (ppm) TIME (HOURS) DISTRIBUTION (ppm) 6654 G25 6654 G26 6654 G37 6654fh For more information www.linear.com/LT6654 9 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Available Options Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagrams Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
