Datasheet ADR130 (Analog Devices) - 4
DescriptionPrecision Series Sub-Band Gap Voltage Reference
Pages / Page16 / 4 — ADR130. Data Sheet. Table 2. Parameter. Symbol. Conditions. Min. Typ Max. …
RevisionD
File Format / SizePDF / 629 Kb
ADR130. Data Sheet. Table 2. Parameter. Symbol. Conditions. Min. Typ Max. Unit
ADR130 Data Sheet Table 2 Parameter Symbol Conditions Min Typ Max Unit
ADR130 Data Sheet
TA = 25°C, VIN = 2.0 V to 18 V, unless otherwise noted. SET (Pin 5) tied to GND (Pin 2).
Table 2. Parameter Symbol Conditions Min Typ Max Unit
OUTPUT VOLTAGE VO A Grade 0.9930 1.0 1.0070 V B Grade 0.9965 1.0 1.0035 V INITIAL ACCURACY ERROR VOERR A Grade −7.0 +7.0 mV B Grade −3.5 +3.5 mV TEMPERATURE COEFFICIENT TCVO −40°C < TA < +125°C A Grade 15 50 ppm/°C B Grade 5 25 ppm/°C LOAD REGULATION −40°C < TA < +125°C; 3 V ≤ VIN ≤ 18 V; −0.25 +0.25 mV/mA 0 mA < IOUT < 4 mA −40°C < TA < +125°C; 3 V ≤ VIN ≤ 18 V; −2.0 +2.0 mV/mA −2 mA < IOUT < 0 mA LINE REGULATION 2.0 V to 18 V, IOUT = 0 mA −40 +10 +40 ppm/V QUIESCENT CURRENT IQ −40°C < TA < +125°C, no load 85 150 µA SHORT-CIRCUIT CURRENT TO GROUND VIN = 2.0 V 15 mA VIN = 18.0 V 50 mA VOLTAGE NOISE 0.1 Hz to 10 Hz 6 µV p-p TURN-ON SETTLING TIME To 0.1%, CLOAD = 0.1 µF 80 µs LONG-TERM STABILITY 1000 hours @ 25°C 100 ppm/1000 hours OUTPUT VOLTAGE HYSTERESIS 150 ppm Rev. C | Page 4 of 16 Document Outline Features Applications Pin Configuration General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Terminology Theory of Operation Power Dissipation Considerations Input Capacitor Output Capacitor Application Notes Basic Voltage Reference Connection Stacking Reference ICs for Arbitrary Outputs Precision Current Source Outline Dimensions Ordering Guide
