Datasheet LTM8020 (Analog Devices) - 2
Description200mA, 36V DC/DC µModule Regulator
Pages / Page16 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION …
File Format / SizePDF / 406 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION http://www.linear.com/product/LTM8020#orderinfo
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION http://www.linear.com/product/LTM8020#orderinfo
LTM8020
V TOP VIEW IN, SHDN Voltage ..40V ADJ Voltage ..5V 5 VOUT BIAS Voltage ...25V 4 V GND IN + BIAS Voltage ..47V 3 BIAS VOUT Voltage ...10V Internal Operating Temperature Range ... –40°C to 125°C 2 VIN Storage Temperature Range .. –55°C to 125°C 1 SHDN ADJ Maximum Solder Temperature ..260°C A B C D E LGA PACKAGE 21-LEAD (6.25mm × 6.25mm × 2.32mm) TJMAX = 125°C, θJA = 23.1°C/W θJA DERIVED FROM 5cm × 5cm PCB WITH 4 LAYERS WEIGHT = 0.25g
ORDER INFORMATION http://www.linear.com/product/LTM8020#orderinfo LEAD FREE FINISH PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE (Note 2)
LTM8020EV#PBF LTM8020V 21-Lead (6.25mm × 6.25mm) –40°C to 85°C LTM8020IV#PBF LTM8020V 21-Lead (6.25mm × 6.25mm) –40°C to 85°C LTM8020MPV#PBF LTM8020MPV 21-Lead (6.25mm × 6.25mm) –55°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ This product is only offered in trays. For more information go to: http://www.linear.com/packaging/. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix.
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. VIN = 10V, VSHDN = 10V, VBIAS = 3V, External CIN = 2.2µF, COUT = 4.7µF. (Note 2) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN Input DC Voltage l 4 36 V VOUT Output DC Voltage 0 < IOUT ≤ 200mA; 167kW < RADJ < ∞ 1.2 5 V RADJ(MIN) Minimum Allowable RADJ (Note 3) 163 kW ILK Leakage from IN to OUT VSHDN = 0V, BIAS = 0V 1.2 6 µA IOUT Continuous Output DC Current 5.5V ≤ VIN ≤ 36V, RADJ = 301k, VO = 3.3V 0 200 mA IQ(VIN) Quiescent Current into IN SHDN = 0.2V, BIAS Open 1 µA BIAS = 3V, Not Switching l 10 18 µA BIAS = 0V, Not Switching 35 50 µA IQ(BIAS) Quiescent Current into BIAS SHDN = 0.2V, BIAS = 0V 0.5 µA BIAS = 3V, Not Switching l 25 60 µA BIAS = 0V, Not Switching 1.5 µA DVOUT/VOUT Line Regulation 5V ≤ VIN ≤ 36V, IOUT = 200mA, RADJ Open 1 % DVOUT/VOUT Load Regulation VIN = 24V, 0 ≤ IOUT ≤ 200mA, VOUT = 3.3V 2 % 8020fe 2 For more information www.linear.com/LTM8020
