Datasheet ADR5040, ADR5041, ADR5043, ADR5044, ADR5045 (Analog Devices) - 7
Description | Precision Micropower Shunt Mode Voltage Reference Applications (5.0 Vout) |
Pages / Page | 15 / 7 — Data Sheet. ADR5040/ADR5041/ADR5043/ADR5044/ADR5045. TYPICAL PERFORMANCE … |
Revision | D |
File Format / Size | PDF / 451 Kb |
Data Sheet. ADR5040/ADR5041/ADR5043/ADR5044/ADR5045. TYPICAL PERFORMANCE CHARACTERISTICS. IR = 150µA. G N. A H. HANG. U O. –10. –15. –40. –25
Data Sheet ADR5040/ADR5041/ADR5043/ADR5044/ADR5045 TYPICAL PERFORMANCE CHARACTERISTICS
TA = 25°C, IIN = 100 μA, unless otherwise noted.
6 15 IR = 150µA IR = 150µA 4 10 2 ) ) V 5 V (m 0 (m E E G N 0 A H –2 HANG C C T T U O –5 OU V –4 V –10 –6 –8
3 5 0
–15
0
–40 –25 –10 5 20 35 50 65 80 95 110 125
0 0 6-
6-
TEMPERATURE (°C)
52
TEMPERATURE (°C)
52 06 06 Figure 2. ADR5041 VOUT Change vs. Temperature Figure 5. ADR5045 VOUT Change vs. Temperature
5 8 6 ) V V) 4 m ( 4 E E (m G N –40°C A 2 3 H CHANG E +125°C E C G G 0 A A T T +25°C L L O 2 V –2 E SE VO +125°C RS E +25°C –4 V 1 VER E RE R –40°C –6 0
4
–8
6 0
0 5 10 15 20
00 0 6-
0 5 10 15 20
6-
I
52 52
SHUNT (mA) I
06
SHUNT (mA)
06 Figure 3. ADR5041 Reverse Voltage Change vs. ISHUNT Figure 6. ADR5045 Reverse Voltage Change vs. ISHUNT
V V IN IN IV IV /D /D 2V 1V V VOUT OUT
0 7 01 00 6- 6- 52
10µs/DIV
52
40µs/DIV
06 06 Figure 4. ADR5041 Start-Up Characteristics Figure 7. ADR5045 Start-Up Characteristics Rev. D | Page 7 of 15 Document Outline Features Applications Pin Configuration General Description Revision History Specifications ADR5040 Electrical Characteristics ADR5041 Electrical Characteristics ADR5043 Electrical Characteristics ADR5044 Electrical Characteristics ADR5045 Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Terminology Theory of Operation Applications Information Precision Negative Voltage Reference Stacking the ADR5040/ADR5041/ADR5043/ADR5044/ADR5045 for User-Definable Outputs Adjustable Precision Voltage Source Programmable Current Source Outline Dimensions Ordering Guide Automotive Products
