ADR512Data SheetABSOLUTE MAXIMUM RATINGSTHERMAL RESISTANCETable 3. ParameterRating θJA is specified for the worst-case conditions, that is, a device Reverse Current 25 mA soldered in a circuit board for surface-mount packages. Forward Current 20 mA Table 4. Thermal Resistance Storage Temperature Range Package Type1θ 2JAθJCUnit RT Package −65°C to +150°C 3-SOT-23 (RT) 230 146 °C/W Operating Temperature Range −40°C to +85°C Junction Temperature Range 1Package power dissipation = (TJMAX − TA)/θJA. 2 RT Package −65°C to +150°C θJA is specified for worst-case conditions, i.e., θJA is specified for device soldered. Lead Temperature Range (Soldering, 60 Sec) 300°C ESD CAUTION Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Rev. A | Page 4 of 12 Document Outline Features Applications Pin Configuration General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Parameter Definitions Temperature Coefficient Thermal Hysteresis Applications Section Adjustable Precision Voltage Source Output Voltage Trim Using the ADR512 with Precision Data Converters Precise Negative Voltage Reference Outline Dimensions Ordering Guide
