Datasheet LT6023, LT6023-1 (Analog Devices) - 8
Description | Dual Micropower, 1.4V/μs Precision Rail-to-Rail Output Amplifier |
Pages / Page | 22 / 8 — TYPICAL. PERFORMANCE CHARACTERISTICS TA = 25°C, VS = ±15V, RL = 100kΩ, … |
File Format / Size | PDF / 784 Kb |
TYPICAL. PERFORMANCE CHARACTERISTICS TA = 25°C, VS = ±15V, RL = 100kΩ, unless. otherwise specified. Input Bias Current vs
LT6023/LT6023-1
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, VS = ±15V, RL = 100kΩ, unless otherwise specified. Input Bias Current vs Input Bias Current vs Differential Temperature Input Voltage 0.1Hz to 10Hz Voltage Noise
4 1 0.75 3 0.5 0.25 2 IB– IB+ 1µV/DIV 0 1 –0.25 INPUT BIAS CURRENT (nA) –0.5 INPUT BIAS CURRENT (µA) 0 –0.75 –1 –1 –50 –25 0 25 50 75 100 125 6 4 2 0 –2 –4 –6 1s/DIV TEMPERATURE (°C) DIFFERENTIAL INPUT VOLTAGE (V) 6023 G09 6023 G10 6023 G11
Voltage Noise Density vs Maximum Undistorted Output Large-Signal Transient Response Frequency Amplitude vs Frequency (5V Step)
1000 35 V ) S = ±5V THD < 40dBc AV = 1 10V STEP ) P–P AV = 1 Hz 30 /√ TAGE (V 5V STEP 25 Y (nV 2V/DIV 20 100 TED OUTPUT VOL 15 10 TAGE NOISE DENSIT VOL 5 10 MAXIMUM UNDISTOR 0 0.01 0.1 1 10 100 1k 10k 0.1 1 10 50µs/DIV FREQUENCY (Hz) FREQUENCY (kHz) 6023 G12 6023 G14 6023 G13
Slew Rate vs Temperature Slew Rate vs Temperature (5V Step) (10V Step) Slew Rate vs Input Step
1 2 3.5 RISING EDGE RISING EDGE 3 0.75 1.5 FALLING EDGE 2.5 /µs) /µs) FALLING EDGE /µs) 2 TE (V 0.5 RISING EDGE TE (V 1 TE (V FALLING EDGE 1.5 SLEW RA SLEW RA SLEW RA 0.25 0.5 1 0.5 0 0 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 0 0 5 10 15 20 25 30 TEMPERATURE (°C) TEMPERATURE (°C) INPUT STEP SIZE (VP–P) 6023 G15 6023 G16 6023 G17 60231fa 8 For more information www.linear.com/LT6023 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Schematic Applications Information Typical Applications Package Description Typical Application Related Parts
