Datasheet LTC6090, LTC6090-5 (Analog Devices) - 7
Description140V CMOS Rail-to-Rail Output, Picoamp Input Current Op Amp
Pages / Page26 / 7 — TYPICAL PERFORMANCE CHARACTERISTICS. Output Impedance vs Frequency. Input …
TYPICAL PERFORMANCE CHARACTERISTICS. Output Impedance vs Frequency. Input Bias Current vs Common
TYPICAL PERFORMANCE CHARACTERISTICS Output Impedance vs Frequency Input Bias Current vs Common
LTC6090/LTC6090-5
TYPICAL PERFORMANCE CHARACTERISTICS Output Impedance vs Frequency Input Bias Current vs Common Output Impedance vs Frequency with Output Disabled (OD = COM) Mode Voltage and Temperature
1000 1000 10000 CL = 10pF VS = ±70V 125°C 100 1000 100°C 100 10 100 80°C DIRECTION OF THE CURRENT IS OUT OF THE PIN 1 10 10 50°C OUTPUT IMPEDACNE (Ω) 0.1 OUTPUT IMPEDANCE (kΩ) INPUT BIAS CURRENT (|pA|) 1 AV = 101V/V 25°C AV = 11V/V AV = 1V/V 5°C 0.01 1 0.1 1 10 100 1000 10000 100000 1 10 100 1000 –80 –60 –40 –20 0 20 40 60 80 FREQUENCY (kHz) FREQUENCY (kHz) COMMON MODE VOLTAGE (V) 6090 G19 6091 G20 6090 G21
Input Bias Current vs Common LTC6090 Large Signal Transient LTC6090-5 Large Signal Transient Mode Voltage and Temperature Response Response
1000 V 80 80 125°C S = ±15V AV = –10V/V AV = –10V/V 60 VS = ±70V 60 VS = ±70V OUTPUT OUTPUT RF = 100kΩ 100 RI = 10kΩ 100°C 40 40 CF = 2pF 85°C 20 20 10 DIRECTION OF THE CURRENT 0 INPUT 0 INPUT IS OUT OF THE PIN –20 –20 OUTPUT, INPUT (V) OUTPUT, INPUT (V) 1 50°C –40 INPUT BIAS CURRENT (|pA|) –40 25°C –60 –60 0.1 –80 –80 –15 –10 –5 0 5 10 15 6090 G23 5µs/DIV 6090 G24 5µs/DIV COMMON MODE VOLTAGE (V) 6090 G22
LTC6090 Falling Edge LTC6090 Rising Edge Small Signal Transient Response Settling Time Settling Time
AV = 1V/V AV = 1V/V AV = 1V/V INPUT OUTPUT OUTPUT STEP (20mV/DIV) OUTPUT STEP (20mV/DIV) 50mV/DIV OUTPUT INPUT INPUT OUTPUT 50mV/DIV INPUT STEP (0.5V/DIV) INPUT STEP (0.5V/DIV) 6090 G16 1µs/DIV 500ns/DIV 6090 G26 500ns/DIV 6090 G27 6090fe For more information www.linear.com/LTC6090 7 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
