Datasheet LTC6090, LTC6090-5 (Analog Devices) - 8
Description140V CMOS Rail-to-Rail Output, Picoamp Input Current Op Amp
Pages / Page26 / 8 — TYPICAL PERFORMANCE CHARACTERISTICS. LTC6090-5 Small Signal. LTC6090-5 …
TYPICAL PERFORMANCE CHARACTERISTICS. LTC6090-5 Small Signal. LTC6090-5 Rising Edge. LTC6090-5 Falling Edge. Transient Response
TYPICAL PERFORMANCE CHARACTERISTICS LTC6090-5 Small Signal LTC6090-5 Rising Edge LTC6090-5 Falling Edge Transient Response
LTC6090/LTC6090-5
TYPICAL PERFORMANCE CHARACTERISTICS LTC6090-5 Small Signal LTC6090-5 Rising Edge LTC6090-5 Falling Edge Transient Response Settling Time Settling Time
A INPUT V = 5V/V AV = 5V/V R OUTPUT F = 40.2kΩ RF = 40.2kΩ RI = 10kΩ RI = 10kΩ INPUT CF = 2pF CF = 2pF 25mV/DIV OUTPUT (50mV OUTPUT (50mV /DIV) /DIV) INPUT /DIV) /DIV) OUTPUT 100mV/DIV INPUT (100mV INPUT (100mV AV = 5V/V OUTPUT RF = 40.2kΩ RI = 10kΩ CF = 2pF 1µs/DIV 6090 G28 500ns/DIV 6090 G29 500ns/DIV 6090 G30
Output Disable (OD) Response Output Voltage Swing Time vs Frequency 0.1Hz to 10Hz Voltage Noise
160 OD-COM AV = –10V/V AV = –10V/V VIN = –0.5V 140 VS = ±70V OUTPUT RF = 100kΩ OD-COM ENABLED 120 RI = 10kΩ = 0V OUTPUT CF = 2pF DISABLED ) 100 P-P OUTPUT (V 80 NOISE 2V/DIV VOUT 2µV/DIV V OUT 60 VOUT = 0V 40 20 LTC6090 LTC6090-5 0 6090 G31 20µs/DIV 1 10 100 1000 6090 G33 TIME (1s/DIV) FREQUENCY (kHz) 6090 G32
OD Pin Input Current Output Voltage Swing High (VOH) Supply Current vs OD Pin Voltage vs OD Pin Voltage vs Load Current and Temperature
3.0 75 800 VS = ±70V V 125°C S = ±70V 125°C VCOM = 0V V 85°C COM = 0V 85°C 2.5 700 50 25°C 25°C –50°C 600 –50°C 2.0 25 500 1.5 (mV) 400 0 V OH 300 1.0 INPUT CURRENT (µA) SUPPLY CURRENT (mA) 125°C OD 200 –25 0.5 85°C 25°C 100 –50°C 0 –50 0 0.5 0.8 1.0 1.3 1.5 1.8 2.0 0 1 2 3 4 5 6 7 0 2 4 6 8 10 OD-COM (V) OD-COM (V) ISOURCE (mA) 6090 G35 6090 G34 6090 G36 6090fe 8 For more information www.linear.com/LTC6090 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
