Datasheet LT6013, LT6014 (Analog Devices) - 10
Description | Single/Dual 145µA, 9.5nV/√Hz, AV ≥5, Rail-to-Rail Output Precision Op Amps |
Pages / Page | 16 / 10 — TYPICAL PERFOR A CE CHARACTERISTICS. Supply Current vs Supply Voltage. … |
File Format / Size | PDF / 346 Kb |
TYPICAL PERFOR A CE CHARACTERISTICS. Supply Current vs Supply Voltage. Warm-Up Drift. THD + Noise vs Frequency
LT6013/LT6014
W U TYPICAL PERFOR A CE CHARACTERISTICS Supply Current vs Supply Voltage Warm-Up Drift THD + Noise vs Frequency
500 3 10 PER AMPLIFIER VS = 5V, 0V 450 VOUT = 2VP-P V) T 400 µ 1 A = 25°C AV = 5 A) ±15V µ 350 2 T 300 A = 85°C 0.1 TA = 25°C 250 0.01 200 ±2.5V 1 THD + NOISE (%) 150 SUPPLY CURRENT ( T 100 A = –40°C 0.001 CHANGE IN OFFSET VOLTAGE ( 50 0 0.0001 0 0 2 4 6 8 10 12 14 16 18 20 30 60 90 120 150 10 100 1k 10k 100k TIME AFTER POWER-ON (SECONDS) FREQUENCY (Hz) SUPPLY VOLTAGE (±V) 60134 G16 60134 G14 60134 G15
THD + Noise vs Frequency Settling Time vs Output Step Channel Separation vs Frequency
10 4 160 V V LT6014 S = ±15V S = 5V, 0V V A 0.1% V OUT = 20VP-P V = 5 140 S = 5V, 0V T T 0.01% T A = 25°C A = 25°C A = 25°C 1 AV = 5 3 120 100 0.1 2 80 0.01 60 THD + NOISE (%) OUTPUT STEP (V) 1 40 CHANNEL SEPARATION (dB) 0.001 20 0.0001 0 0 10 100 1k 10k 0 5 10 15 20 25 30 1 10 100 1k 10k 100k 1M FREQUENCY (Hz) SETTLING TIME (µs) FREQUENCY (Hz) 60134 G17 60134 G20 60134 G18
CMRR vs Frequency PSRR vs Frequency, Single Supply PSRR vs Frequency, Split Supplies
160 140 140 TA = 25°C VS = 5V, 0V VS = ±15V 140 TA = 25°C TA = 25°C 120 120 120 100 100 POSITIVE 100 SUPPLY 80 80 80 60 60 60 NEGATIVE 40 40 SUPPLY 40 20 20 20 COMMON MODE REJECTION RATIO (dB) POWER SUPPLY REJECTION RATIO (dB) POWER SUPPLY REJECTION RATIO (dB) 0 0 0 1 10 100 1k 10k 100k 1M 0.1 1 10 100 1k 10k 100k 1M 0.1 1 10 100 1k 10k 100k 1M FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz) 60134 G21 60134 G19 60134 G22 60134fb 10
