Datasheet LT6010 (Analog Devices) - 6
Description135µA, 14nV/√Hz, Rail-to-Rail Output Precision Op Amp with Shutdown
Pages / Page16 / 6 — ELECTRICAL CHARACTERISTICS The
File Format / SizePDF / 304 Kb
LT6010
C. VS =
15V, VCM = 0V, RL to 0V; SHDN = –14.8V, unless otherwise specified. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SR Slew Rate AV = –10, RF = 50k, RG = 5k 0.08 0.11 V/µs TA = 0°C to 70°C ● 0.07 V/µs TA = –40°C to 85°C ● 0.05 V/µs GBW Gain Bandwidth Product f = 10kHz 275 350 kHz ● 250 kHz ts Settling Time AV = –1, 0.01%, VOUT = 0V to 10V 85 µs tr, tf Rise Time, Fall Time AV = 1, 10% to 90%, 0.1V Step 1 µs ISHDN SHDN Pin Current SHDN ≤ V– + 0.2V (On) ● 0.25 µA SHDN = V– + 2.0V (Off) ● 15 25 µA tSHDN SHDN Turn-On, Turn-Off Time SHDN = V– (On) to V– + 2.0V (Off) 25 µs SHDN = V– + 2.0V (Off) to V– (On) 25 µs IS Supply Current SHDN ≤ V– + 0.2V (On) 260 330 µA TA = 0°C to 70°C ● 380 µA TA = –40°C to 85°C ● 400 µA SHDN = V– + 2.0V (Off) 18 50 µA
Note 1:
Absolute Maximum Ratings are those beyond which the life of the from 0°C to 70°C and is designed, characterized and expected to meet device may be impaired. specified performance from –40°C to 85°C but is not tested or QA
Note 2:
The inputs are protected by back–to–back diodes and internal sampled at these temperatures. The LT6010I is guaranteed to meet series resistors. If the differential input voltage exceeds 10V, the input specified performance from –40°C to 85°C. current must be limited to less than 10mA.
Note 6:
This parameter is not 100% tested.
Note 3:
A heat sink may be required to keep the junction temperature
Note 7:
The specifications for VOS, IB and IOS depend on the grade and on below absolute maximum ratings. the package. The following table clarifies the notations used in the
Note 4:
Both the LT6010C and LT6010I are guaranteed functional over the specification table: operating temperature range of –40°C to 85°C.
Standard Grade A Grade Note 5:
The LT6010C is guaranteed to meet the specified performance S8 Package LT6010S8 LT6010AS8 DFN Package LT6010DD LT6010ADD
W U TYPICAL PERFOR A CE CHARACTERISTICS Input Offset Voltage Offset Voltage Distribution of Input Offset Voltage vs Temperature vs Input Common Mode Voltage
30 125 120 VS = 5V, 0V LT6010AS8 VS = 5V, 0V VS = ±15V T 100 A = 25°C REPRESENTATIVE UNITS TYPICAL PART 25 100 75 µV) 50 80 20 µV) T 25 A = 85°C 60 15 0 TA = –40°C –25 40 10 T –50 A = 25°C PERCENT OF UNITS (%) OFFSET VOLTAGE ( OFFSET VOLTAGE ( 20 –75 5 0 –100 0 –125 –20 –45 –35 –25 –15 –5 5 15 25 35 45 –50 –25 0 25 50 75 100 125 –15 –10 –5 0 5 10 15 INPUT OFFSET VOLTAGE (µV) TEMPERATURE (°C) INPUT COMMON MODE VOLTAGE (V) 6010 G01 6010 G02 6010 G03 sn6010 6010fs 6
