Datasheet LT6011, LT6012 (Analog Devices) - 9
DescriptionDual/Quad 135µA, 14nV/√Hz, Rail-to-Rail Output Precision Op Amp
Pages / Page20 / 9 — Typical perForMance characTerisTics. Output Voltage Swing. Output …
File Format / SizePDF / 384 Kb
Typical perForMance characTerisTics. Output Voltage Swing. Output Saturation Voltage. 0.01Hz to 1Hz Noise. vs Temperature
Typical perForMance characTerisTics Output Voltage Swing Output Saturation Voltage 0.01Hz to 1Hz Noise vs Temperature
LT6011/LT6012
Typical perForMance characTerisTics Output Voltage Swing Output Saturation Voltage 0.01Hz to 1Hz Noise vs Temperature vs Load Current (Output High)
V+ 1 VS = ±15V VS = 5V, 0V VS = 5V, 0V TA = 25°C –20 NO LOAD –40 OUTPUT HIGH TA = 85°C –60 TA = 25°C 0.1 60 OUTPUT LOW TA = –40°C NOISE VOLTAGE (0.2µV/DIV) 40 OUTPUT VOLTAGE SWING (mV) 20 OUTPUT HIGH SATURATION VOLTAGE (V) V– 0.01 0 10 20 30 40 50 60 70 80 90 100 –50 –25 0 25 50 75 100 125 0.01 0.1 1 10 TIME (SEC) TEMPERATURE (°C) LOAD CURRENT (mA) 6011 G10 6011 G11 6011 G12
Output Saturation Voltage vs Load Current (Output Low) Supply Current vs Supply Voltage Warm-Up Drift
1 500 3 VS = 5V, 0V PER AMPLIFIER 450 400 T ±15V A = 85°C 350 TA = 85°C 2 T 300 A = 25°C TA = 25°C 0.1 250 TA = –40°C 200 ±2.5V T 1 SUPPLY CURRENT (µA) 150 A = –40°C 100 CHANGE IN OFFSET VOLTAGE (µV) OUTPUT LOW SATURATION VOLTAGE (V) 50 0.01 0 0 0.01 0.1 1 10 0 2 4 6 8 10 12 14 16 18 20 30 60 90 120 150 LOAD CURRENT (mA) SUPPLY VOLTAGE (±V) TIME AFTER POWER-ON (SECONDS) 6011 G13 6011 G14 6011 G15
THD + Noise vs Frequency THD + Noise vs Frequency Settling Time vs Output Step
10 10 10 V V V S = 5V, 0V S = ±15V S = ±15V V V A OUT = 2VP-P IN = 20VP-P V = 1 T T 1 A = 25°C 1 A = 25°C 8 AV = 1: RL = 10k AV = –1: RF = RG = 10k 0.1 0.1 6 0.1% 0.01% 0.01 0.01 AV = –1 4 THD + NOISE (%) AV = –1 THD + NOISE (%) OUTPUT STEP (V) AV = 1 AV = 1 0.001 0.001 2 0.0001 0.0001 0 10 100 1k 10k 100k 10 100 1k 10k 0 10 20 30 40 50 60 70 80 90 FREQUENCY (Hz) FREQUENCY (Hz) SETTLING TIME (µs) 6011 G16 6011 G17 6011 G18 60112fc 9 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Package/Order Information Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Simplified Schematic Package Description Revision History Typical Application Related Parts
