Datasheet LT6011, LT6012 (Analog Devices) - 8
DescriptionDual/Quad 135µA, 14nV/√Hz, Rail-to-Rail Output Precision Op Amp
Pages / Page20 / 8 — Typical perForMance characTerisTics. Input Offset Voltage. Offset …
File Format / SizePDF / 384 Kb
Typical perForMance characTerisTics. Input Offset Voltage. Offset Voltage. Distribution of Input Offset Voltage. vs Temperature
Typical perForMance characTerisTics Input Offset Voltage Offset Voltage Distribution of Input Offset Voltage vs Temperature
LT6011/LT6012
Typical perForMance characTerisTics Input Offset Voltage Offset Voltage Distribution of Input Offset Voltage vs Temperature vs Input Common Mode Voltage
30 125 120 VS = 5V, 0V LT6011S8, VS = 5V, 0V VS = ±15V TA = 25°C LT6012S 100 REPRESENTATIVE UNITS TYPICAL PART 25 100 75 80 20 50 TA = 85°C 25 60 15 0 TA = –40°C –25 40 10 T –50 A = 25°C PERCENT OF UNITS (%) OFFSET VOLTAGE (µV) OFFSET VOLTAGE (µV) 20 –75 5 0 –100 0 –125 –20 –90 –70 –50 –30 –10 10 30 50 70 90 –50 –25 0 25 50 75 100 125 –15 –10 –5 0 5 10 15 INPUT OFFSET VOLTAGE (µV) TEMPERATURE (°C) INPUT COMMON MODE VOLTAGE (V) 6011 G01 6011 G02 6011 G03
Input Bias Current Distribution of Input Bias Current Input Bias Current vs Temperature vs Input Common Mode Voltage
25 1600 300 VS = 5V, 0V LT6011A, VS = 5V, 0V VS = ±15V TA = 25°C LT6012A 1400 TYPICAL PART TYPICAL PART 20 1200 200 13.9V 1000 TA = 85°C 15 100 T 800 A = –40°C 600 10 0 TA = 25°C 400 PERCENT OF UNITS (%) –14.2V INPUT BIAS CURRENT (pA) 5 INPUT BIAS CURRENT (pA) 200 I – –100 B 0 I + B 0 –200 –200 –400 –300 –200 –100 0 100 200 300 400 –50 –25 0 25 50 75 100 125 –15 –10 –5 0 5 10 15 INPUT BIAS CURRENT (pA) TEMPERATURE (°C) COMMON MODE VOLTAGE (V) 6011 G04 6011 G05 1635 G06
Total Input Noise en, in vs Frequency vs Source Resistance 0.1Hz to 10Hz Noise
1000 10 ) INPUT CURRENT NOISE DENSITY (fA/√ VS = ±15V VS = 5V, 0V VS = ±15V Hz TA = 25°C TA = 25°C TA = 25°C ) f = 1kHz 1 Hz UNBALANCED CURRENT NOISE SOURCE RESISTORS UNBALANCED SOURCE RESISTORS 0.1 100 100 TOTAL NOISE 0.01 RESISTOR NOISE ONLY TOTAL INPUT NOISE (µV/√ 0.001 NOISE VOLTAGE (0.2µV/DIV) VOLTAGE NOISE Hz INPUT VOLTAGE NOISE DENSITY (nV/√ ) 10 0.0001 1 10 100 1000 100 1k 10k 100k 1M 10M 100M 0 1 2 3 4 5 6 7 8 9 10 FREQUENCY (Hz) SOURCE RESISTANCE (Ω) TIME (SEC) 6011 G07 6011 G08 6011 G09 60112fc 8 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Package/Order Information Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Simplified Schematic Package Description Revision History Typical Application Related Parts
