Datasheet LTC3879 (Analog Devices) - 2
DescriptionFast, Wide Operating Range No RSENSE Step-Down Controller
Pages / Page28 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. …
File Format / SizePDF / 314 Kb
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
LTC3879
Input Supply Voltage (VIN) ... –0.3V to 40V VFB, ITH Voltages ... –0.3V to 2.7V ION Voltage ... –0.3V to 40V Operating Temperature Range (Note 4)..–40°C to 85°C BOOST Voltage .. –0.3V to 46V Junction Temperature (Note 2) ... 125°C SW Voltage ... –5V to 40V Storage Temperature Range ...–65°C to 150°C INTVCC, (BOOST-SW), TRACK/SS, RUN, Lead Temperature (Soldering, 10 sec) PGOOD Voltages .. –0.3V to 6V MSOP Only ... 300°C MODE, VRNG Voltages ..–0.3V to INTVCC + 0.3V
PIN CONFIGURATION
TOP VIEW TOP VIEW BOOST TG SW PGND TRACK/SS 1 16 BOOST 16 15 14 13 PGOOD 2 15 TG TRACK/SS 1 12 BG V 3 RNG 14 SW MODE 4 13 PGND PGOOD 2 11 INTV 17 CC I 5 17 TH 12 BG VRNG 3 10 V SGND 6 11 INTV IN CC I 7 ON 10 VIN MODE 4 9 RUN V 8 FB 9 RUN 5 6 7 8 MSE PACKAGE 16-LEAD PLASTIC MSOP I TH I ON FBV SGND TJMAX = 125°C, θJA = 40°C/W EXPOSED PAD (PIN 17) IS SGND, MUST BE SOLDERED TO PCB UD PACKAGE 16-LEAD (3mm s 3mm) PLASTIC QFN TJMAX = 125°C, θJA = 68°C/W, θJC = 4.2°C/W EXPOSED PAD (PIN 17) IS SGND, MUST BE SOLDERED TO PCB
LTC3879EMSE#PBF LTC3879EMSE#TRPBF 3879 16-Lead Plastic MSOP –40°C to 85°C (Note 4) LTC3879IMSE#PBF LTC3879IMSE#TRPBF 3879 16-Lead Plastic MSOP –40°C to 85°C (Note 4) LTC3879EUD#PBF LTC3879EUD#TRPBF LDTM 16-Lead (3mm × 3mm) Plastic QFN –40°C to 85°C (Note 4) LTC3879IUD#PBF LTC3879IUD#TRPBF LDTM 16-Lead (3mm × 3mm) Plastic QFN –40°C to 85°C (Note 4) Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. *The temperature grade is identifi ed by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/ 3879f 2
