Datasheet LTC3879 (Analog Devices) - 3
Description | Fast, Wide Operating Range No RSENSE Step-Down Controller |
Pages / Page | 28 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply … |
File Format / Size | PDF / 314 Kb |
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
LTC3879
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 15V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Main Control Loop
Input Operating Voltage Range 4 38 V IQ Input DC Supply Current Normal 1350 2000 μA Shutdown Supply Current 18 35 μA VFBREF Feedback Reference Voltage ITH = 1.2V (Note 3) l 0.594 0.6 0.606 V Feedback Voltage Line Regulation VIN = 4V to 30V, ITH = 1.2V (Note 3) 0.005 %/V Feedback Voltage Load Regulation ITH = 0.5V to 1.9V (Note 3) l –0.05 –0.3 % IFB Feedback Input Current VFB = 0.6V –5 ±50 nA gm(EA) Error Amplifi er Transconductance ITH = 1.2V (Note 3) 1.4 1.7 2 mS VMODE MODE Threshold 0.76 0.8 0.84 V MODE Pin Current VMODE = 0.8V 0 ±1 μA tON On-Time ION = 30μA 198 233 268 ns ION = 15μA 370 440 510 ns tON(MIN) Minimum On-Time ION = 180μA 43 75 ns tOFF(MIN) Minimum Off-Time ION = 30μA 220 300 ns VSENSE(MAX) Valley Current Sense Threshold VRNG = 1V, VFB = 0.56V l 108 133 165 mV VPGND – VSW VRNG = 0V, VFB = 0.56V l 22 30 48 mV Peak Current = Valley + Ripple VRNG = INTVCC, VFB = 0.56V l 62 75 98 mV VSENSE(MIN) Minimum Current Sense Threshold VRNG = 1V, VFB = 0.64V –61 mV VPGND – VSW VRNG = 0V, VFB = 0.64V –12 mV Force Continuous Operation VRNG = INTVCC, VFB = 0.64V –33 mV VRUN RUN On Threshold VRUN Rising 1.3 1.5 1.7 V IRUN RUN Pull-Up Current VRUN = 0V –1.2 μA ITRACK/SS Soft-Start Charging Current VTRACK/SS = 0V –0.45 –1 –2 μA INTVCC Undervoltage Lockout Falling l 3.3 3.9 V INTVCC Undervoltage Lockout Release Rising l 3.6 4 V TG Driver Pull-Up On-Resistance TG High 2.5 Ω TG Driver Pull-Down On-Resistance TG Low 1.2 Ω BG Driver Pull-Up On-Resistance BG High 2.5 Ω BG Driver Pull-Down On-Resistance BG Low 0.7 Ω TG Rise Time CLOAD = 3300pF (Note 5) 20 ns TG Fall Time CLOAD = 3300pF (Note 5) 20 ns BG Rise Time CLOAD = 3300pF (Note 5) 20 ns BG Fall Time CLOAD = 3300pF (Note 5) 20 ns Top Gate Off to Bottom Gate On Delay CLOAD = 3300pF Each Driver (Note 5) 15 ns Synchronous Switch-On Delay Time Bottom Gate Off to Top Gate On Delay CLOAD = 3300pF Each Driver (Note 5) 15 ns Top Switch-On Delay Time 3879f 3
