Datasheet LTC6410-6 (Analog Devices) - 4
DescriptionLow Distortion, Low Noise Differential IF Amplifier with Configurable Input Impedance
Pages / Page16 / 4 — The. 5V DC ELECTRICAL CHARACTERISTICS. denotes the specifi cations which …
File Format / SizePDF / 359 Kb
The. 5V DC ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply over the full
The 5V DC ELECTRICAL CHARACTERISTICS denotes the specifi cations which apply over the full
LTC6410-6
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. V+ = 5V, V– = 0V, SHDN = 3V, +IN is shorted to +TERM, –IN is shorted to –TERM, VINCM = VBIAS = 2.5V, +IN = –IN = 2.5V, input source resistance (RS) is 25
Ω
on each input (50
Ω
differential), RL = 50
Ω
from +OUT to –OUT, unless otherwise noted. VBIAS is defi ned as the voltage on theVBIAS pin. VOUTCM is defi ned as (+OUT + –OUT)/2. VINCM is defi ned as (+IN + –IN)/2. VINDIFF is defi ned as (+IN – –IN). VOUTDIFF is defi ned as (+OUT – –OUT). See DC test circuit schematic. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
GDIFF Differential Gain (Low Frequency S21) VIN = ±0.2V 5 6.1 6.7 dB l 4.7 7.0 dB VSWINGDIFF Differential Output Voltage Swing VOUTDIFF, VIN = ±4V 4.1 4.8 VP-P l 3.5 VP-P VSWINGMIN Output Swing Low Single-Ended +OUT, –OUT, VIN = ±4V 1.1 1.4 V l 1.6 V VSWINGMAX Output Swing High Single-Ended +OUT, –OUT, VIN = ±4V 3.2 3.5 V l 3.0 V IS Supply Current 125 150 mA l 160 mA
SHDN Pin
VIL SHDN Input Low Voltage l 1.8 2.0 V VIH SHDN Input High Voltage l 2.8 3 V IIL SHDN Input Low Current SHDN = 1.8V l –300 –110 0 μA IIH SHDN Input High Current SHDN = 3V l –200 –60 0 μA
AC ELECTRICAL CHARACTERISTICS The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. V+ = 3V, V– = 0V, SHDN = 2V, +IN is shorted to +TERM, –IN is shorted to –TERM, VINCM = VBIAS = 1.5V, input source resistance (RS) is 25
Ω
on each input (50
Ω
Ω
from +OUT to –OUT, +IN and –IN are AC-coupled, unless otherwise noted. VBIAS is defi ned as the voltage on theVBIAS pin. VOUTCM is defi ned as (+OUT + –OUT)/2. VINCM is defi ned as (+IN + –IN)/2. VINDIFF is defi ned as (+IN – –IN). VOUTDIFF is defi ned as (+OUT – –OUT). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
–3dBBW –3dB Bandwidth VINDIFF = –10dBm 1 1.4 GHz 0.1dBBW Bandwidth for 0.1dB Flatness VINDIFF = –10dBm 150 MHz 0.5dBBW Bandwidth for 0.5dB Flatness VINDIFF = –10dBm 300 MHz SR Slew Rate 1.5 V/ns ts 1% Settling Time 1% Settling for a 1VP-P VOUTDIFF Step 3 ns tON Turn-On Time SHDN = 0V to 3V, +OUT and –OUT Within 10% of Final Values 30 ns tOFF Turn-Off Time SHDN = 3V to 0V, +OUT and –OUT Within 10% of Final Values 30 ns
Common Mode Voltage Control (VBIAS Pin)
–3dBBWCM Common Mode Small-Signal 0.2VP-P at VBIAS, Measured VOUTCM 1 GHz –3dB Bandwidth SRCM Common Mode Slew Rate 100 V/μs
Noise/Harmonic Performance Input/Output Characteristics 10MHz Signal
HD2 Second Harmonic Distortion VOUTDIFF = 0dBm –85 dBc HD3 Third Harmonic Distortion VOUTDIFF = 0dBm –71 dBc 64106fa 4
