Datasheet LTC6404 (Analog Devices) - 3
Description600MHz, Low Noise, High Precision Fully Differential Input/Output Amplifier/Driver
Pages / Page28 / 3 — LTC6404 DC ELECTRICAL CHARACTERISTICS The. denotes the specifi cations …
File Format / SizePDF / 347 Kb
LTC6404 DC ELECTRICAL CHARACTERISTICS The. denotes the specifi cations which apply over
LTC6404 DC ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over
LTC6404
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. V+ = 3V, V– = 0V, VCM = VOCM = VICM = Mid-Supply, VSHDN = OPEN, RL = OPEN, RBAL = 100k (See Figure 1). For the LTC6404-1: RI = 100Ω, RF = 100Ω. For the LTC6404-2: RI = 100Ω, R + F = 200Ω. For the LTC6404-4: RI = 100Ω, RF = 402Ω, unless otherwise noted. VS is defi ned (V+ – V–). VOUTCM = (VOUT + VOUT )/2. V + + ICM is defi ned (VIN + VIN )/2. VOUTDIFF is defi ned (VOUT – VOUT ). VINDIFF = (VINP – VINM) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOSDIFF Differential Offset Voltage (Input Referred) VS = 2.7V to 5.25V l ±0.5 ±2 mV ΔVOSDIFF/ΔT Differential Offset Voltage Drift (Input Referred) VS = 2.7V to 5.25V 1 μV/°C IB Input Bias Current (Note 6) VS = 2.7V to 5.25V l –60 –23 0 μA ΔIB/ΔT Input Bias Current Drift (Note 6) VS = 2.7V to 5.25V 0.01 μA/°C IOS Input Offset Current (Note 6) VS = 2.7V to 5.25V l ±1 ±10 μA RIN Input Resistance Common Mode 1000 kΩ Differential Mode 3 kΩ CIN Input Capacitance 1 pF en Differential Input Referred Noise Voltage Density f = 1MHz 1.5 nV/√Hz in Input Noise Current Density f = 1MHz 3 pA/√Hz enVOCM Input Referred Common Mode Noise Voltage f = 1MHz, Referred to VOCM Pin Density LTC6404-1 9 nV/√Hz LTC6404-2 10.5 nV/√Hz LTC6404-4 27 nV/√Hz VICMR Input Signal Common Mode Range VS = 3V l 0 1.6 V (Note 7) VS = 5V l 0 3.6 V CMRRI Input Common Mode Rejection Ratio VS = 3V, ΔVCM = 0.75V 60 dB (Note 8) (Input Referred) ΔVICM/ΔVOSDIFF VS = 5V, ΔVCM = 1.25V 60 dB CMRRIO Output Common Mode Rejection Ratio VS = 5V, ΔVOCM = 1V 66 dB (Note 8) (Input Referred) ΔVOCM/ΔVOSDIFF PSRR Differential Power Supply Rejection VS = 2.7V to 5.25V l 60 94 dB (Note 9) (ΔVS/ΔVOSDIFF) PSRRCM Output Common Mode Power Supply Rejection VS = 2.7V to 5.25V (Note 9) (ΔVS/ΔVOSCM) LTC6404-1 l 50 63 dB LTC6404-2 l 50 63 dB LTC6404-4 l 40 51 dB GCM Common Mode Gain (ΔVOUTCM/ΔVOCM) VS = 5V, ΔVOCM = 1V LTC6404-1 l 1 V/V LTC6404-2 l 1 V/V LTC6404-4 l 0.99 V/V Common Mode Gain Error VS = 5V, ΔVOCM = 1V LTC6404-1 l –0.6 –0.125 0.1 % LTC6404-2 l –0.6 –0.25 0.1 % LTC6404-4 l –1.6 –1 –0.4 % BAL Output Balance (ΔVOUTCM/ΔVOUTDIFF) ΔVOUTDIFF = 2V, Single-Ended Input LTC6404-1 l –60 –40 dB LTC6404-2 l –60 –40 dB LTC6404-4 l –53 –40 dB ΔVOUTDIFF = 2V, Differential Input LTC6404-1 l –66 –40 dB LTC6404-2 l –66 –40 dB LTC6404-4 l –66 –40 dB VOSCM Common Mode Offset Voltage (VOUTCM – VOCM) VS = 2.7V to 5.25V LTC6404-1 l ±10 ±25 mV LTC6404-2 l ±20 ±50 mV LTC6404-4 l ±40 ±100 mV 6404f 3
