Datasheet LT6205, LT6206, LT6207 (Analog Devices) - 7
DescriptionQuad Single Supply 3V, 100MHz Video Op Amps
Pages / Page18 / 7 — TYPICAL PERFORMANCE CHARACTERISTICS. Supply Current per Amplifi er. VOS …
File Format / SizePDF / 267 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Supply Current per Amplifi er. VOS Distribution. vs Supply Voltage. Minimum Supply Voltage
TYPICAL PERFORMANCE CHARACTERISTICS Supply Current per Amplifi er VOS Distribution vs Supply Voltage Minimum Supply Voltage
LT6205/LT6206/LT6207
40 5 100 VS = 5V, 0V V) 35 VCM = 1V TA = 125°C 0 4 30 TAGE (μ T –100 A = 25°C 25 3 TA = –55°C –200 TA = –55°C 20 –300 TA =125°C 15 2 –400 TA = 25°C PERCENT OF UNITS (%) 10 Y CURRENT PER AMPLIFIER (mA) 1 5 –500 SUPPL CHANGE IN INPUT OFFSET VOL 0 0 –600 –3 –2 –1 0 1 2 3 0 1 2 3 4 5 6 7 8 9 10 11 12 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 INPUT OFFSET VOLTAGE (mV) TOTAL SUPPLY VOLTAGE (V) TOTAL SUPPLY VOLTAGE (V) 620567 G01 620567 G02 620567 G03
Change in Offset Voltage vs Input Input Bias Current vs Input Common Mode Voltage Common Mode Voltage Input Bias Current vs Temperature
1000 –2 –4 VS = 5V, 0V VS = 5V, 0V VS = 5V, 0V –3 –5 VCM = 1V V) 800 –4 –6 –5 600 –7 –6 TA = 125°C –7 –8 TAGE CHANGE (μ 400 –8 –9 T T A = 25°C –9 A = 25°C –10 INPUT BIAS CURRENT (μA) INPUT BIAS CURRENT (μA) OFFSET VOL 200 –10 TA =125°C –11 –11 TA = –55°C TA = –55°C 0 –12 –12 0 1 2 3 4 5 0 1 2 3 4 5 –50 –25 0 25 50 75 100 125 INPUT COMMON MODE VOLTAGE (V) INPUT COMMON MODE VOLTAGE (V) TEMPERATURE (°C) 620567 G04 620567 G05 620567 G06
Output Saturation Voltage Output Saturation Voltage Short-Circuit Current vs Load Current (Output Low) vs Load Current (Output High) vs Temperature
10 10 75 VS = 5V, 0V VS = 5V, 0V V SINKING OD = 30mV VOD = 30mV 70 TA = 125°C SOURCING GE (V) TA = 125°C GE (V) 65 VS = 5V, 0V TA TA V 1 1 CM = 1V 60 SINKING T T A = 25°C A = 25°C TION VOL TION VOL 55 SOURCING TURA TURA T-CIRCUIT CURRENT (mA) 50 0.1 0.1 TA = –55°C TA = –55°C 45 VS = 3V, 0V VCM = 1V OUTPUT SA OUTPUT SA 40 OUTPUT SHOR 0.01 0.01 35 0.01 0.1 1 10 100 0.01 0.1 1 10 100 –50 –25 0 25 50 75 100 125 LOAD CURRENT (mA) LOAD CURRENT (mA) TEMPERATURE (°C) 620567 G07 620567 G08 620567 G09 620567fc 7 Document Outline FEATURES DESCRIPTION APPLICATIONS TYPICAL APPLICATION ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION ORDER INFORMATION ELECTRICAL CHARACTERISTICS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION TYPICAL APPLICATION PACKAGE DESCRIPTION REVISION HISTORY TYPICAL APPLICATION RELATED PARTS
