Datasheet LT6205, LT6206, LT6207 (Analog Devices) - 9
DescriptionQuad Single Supply 3V, 100MHz Video Op Amps
Pages / Page18 / 9 — TYPICAL PERFORMANCE CHARACTERISTICS. Gain Bandwidth and Phase Margin vs …
File Format / SizePDF / 267 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Gain Bandwidth and Phase Margin vs Temperature. Slew Rate vs Temperature
TYPICAL PERFORMANCE CHARACTERISTICS Gain Bandwidth and Phase Margin vs Temperature Slew Rate vs Temperature
LT6205/LT6206/LT6207
TYPICAL PERFORMANCE CHARACTERISTICS Gain Bandwidth and Phase Margin vs Temperature Slew Rate vs Temperature Slew Rate vs Closed-Loop Gain
55 750 750 R A V L = 1k V = –1 S = p5V C V 50 R V L = 5pF S = p5V 700 G = RF = 1k O = –4V to 4V RISING V 700 S = p5V RL = 1k R 45 L = 1k PHASE MARGIN (DEG) 650 TA = 25°C 40 650 PHASE MARGIN FALLING V /μs) 600 S = p5V /μs) RISING 35 VS = 3V, 0V 600 TE (V 550 TE (V RISING V 550 120 V S = 5V, 0V S = p5V 500 FALLING 110 SLEW RA SLEW RA 500 GAIN BANDWIDTH (MHz) 450 100 VS = 3V, 0V FALLING VS = 5V, 0V 400 450 90 GAIN BANDWIDTH 80 350 400 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 2 3 4 5 TEMPERATURE (°C) TEMPERATURE (°C) GAIN (AV) 620567 G19 620567 G20 620567 G21
Power Supply Rejection Ratio Closed-Loop Gain vs Frequency Output Impedance vs Frequency vs Frequency
15 1000 90 TA = 25°C VS = 5V, 0V VS = 5V, 0V 12 CL = 5pF TA = 25°C 80 TA = 25°C A 9 V = +1 VS = p5V V TIO (dB) 70 CM = 0V 100 6 AV = 10 60 –PSRR 3 +PSRR AV = 1 50 0 10 AV = 2 40 GAIN (dB) –3 V Y REJECTION RA S = 3V 30 –6 VCM = 1V OUTPUT IMPEDANCE (Ω) 1 –9 20 –12 POWER SUPPL 10 –15 0.1 0 100k 1M 10M 100M 500M 100k 1M 10M 100M 500M 10k 100k 1M 10M 100M FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz) 620567 G22 620567 G23 620567 G24
Common Mode Rejection Ratio Series Output Resistor vs Frequency Channel Separation vs Frequency vs Capacitive Load
100 120 40 V V V S = p5V S = p5V S = 5V, 0V 90 T LT6206 CH A-B A A = 25°C 110 35 V = 1 LT6207 CH A-D, CH B-C TA = 25°C RS = 10Ω, RL = d TIO (dB) 80 T 100 A = 25°C 30 70 90 25 60 50 80 20 RS = 20Ω, RL = d 40 TAGE GAIN (dB) 70 15 OVERSHOOT (%) 30 VOL 60 10 20 RL = RS = 50Ω 50 5 COMMON MODE REJECTION RA 10 0 40 0 10k 100k 1M 10M 100M 1G 1M 10M 100M 10 100 1000 FREQUENCY (Hz) FREQUENCY (Hz) CAPACITIVE LOAD (pF) 620567 G25 620567 G26 620567 G27 620567fc 9 Document Outline FEATURES DESCRIPTION APPLICATIONS TYPICAL APPLICATION ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION ORDER INFORMATION ELECTRICAL CHARACTERISTICS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION TYPICAL APPLICATION PACKAGE DESCRIPTION REVISION HISTORY TYPICAL APPLICATION RELATED PARTS
