DatasheetLT6200, LT6200-5 LT6200-10, LT6201 (Analog Devices) - 3
Description165MHz, Rail-to-Rail Input and Output, 0.95nV/√Hz Low Noise, Op Amp Family
Pages / Page26 / 3 — orDer inForMaTion. SPECIFIED. LEAD FREE FINISH. TAPE AND REEL. PART …
File Format / SizePDF / 548 Kb
orDer inForMaTion. SPECIFIED. LEAD FREE FINISH. TAPE AND REEL. PART MARKING*. PACKAGE DESCRIPTION. TEMPERATURE RANGE
orDer inForMaTion SPECIFIED LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LT6200/LT6200-5 LT6200-10/LT6201
LT6200CS8-10#PBF LT6200CS8-10#TRPBF 620010 8-Lead Plastic SO 0°C to 70°C LT6200IS8-10#PBF LT6200IS8-10#TRPBF 200I10 8-Lead Plastic SO –40°C to 85°C LT6201CDD#PBF LT6201CDD #TRPBF LADG 8-Lead (3mm × 3mm) Plastic DFN 0°C to 70°C LT6201CS8#PBF LT6201CS8 #TRPBF 6201 8-Lead Plastic SO 0°C to 70°C LT6201IS8 #PBF LT6201IS8 #TRPBF 6201I 8-Lead Plastic SO –40°C to 85°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/
elecTrical characTerisTics TA = 25°C, VS = 5V, 0V; VS = 3V, 0V; VCM = VOUT = half supply, VSHDN = OPEN, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage VS = 5V, VCM = Half Supply 0.1 1 mV VS = 3V, VCM = Half Supply 0.9 2.5 mV VS = 5V, VCM = V+ to V – 0.6 2 mV VS = 3V, VCM = V+ to V – 1.8 4 mV Input Offset Voltage Match VCM = Half Supply 0.2 1.1 mV (Channel-to-Channel) (Note 11) VCM = V– to V+ 0.5 2.2 mV IB Input Bias Current VCM = Half Supply –40 –10 µA VCM = V+ 8 18 µA VCM = V– –50 –23 µA ∆IB IB Shift VCM = V– to V+ 31 68 µA IB Match (Channel-to-Channel) (Note 11) VCM = V– to V+ 0.3 5 µA IOS Input Offset Current VCM = Half Supply 0.1 4 µA VCM = V+ 0.02 4 µA VCM = V– 0.4 5 µA Input Noise Voltage 0.1Hz to 10Hz 600 nVP-P en Input Noise Voltage Density f = 100kHz, VS = 5V 1.1 nV/√Hz f = 10kHz, VS = 5V 1.5 2.4 nV/√Hz in Input Noise Current Density, Balanced Source f = 10kHz, VS = 5V 2.2 pA/√Hz Unbalanced Source f = 10kHz, VS = 5V 3.5 pA/√Hz Input Resistance Common Mode 0.57 MΩ Differential Mode 2.1 kΩ CIN Input Capacitance Common Mode 3.1 pF Differential Mode 4.2 pF AVOL Large-Signal Gain VS = 5V, VO = 0.5V to 4.5V, RL = 1k to VS/2 70 120 V/mV VS = 5V, VO = 1V to 4V, RL = 100Ω to VS/2 11 18 V/mV VS = 3V, VO = 0.5V to 2.5V, RL = 1k to VS/2 17 70 V/mV CMRR Common Mode Rejection Ratio VS = 5V, VCM = V– to V+ 65 90 dB VS = 5V, VCM = 1.5V to 3.5V 85 112 dB VS = 3V, VCM = V– to V+ 60 85 dB CMRR Match (Channel-to-Channel) (Note 11) VS = 5V, VCM = 1.5V to 3.5V 80 105 dB PSRR Power Supply Rejection Ratio VS = 2.5V to 10V, LT6201DD VS = 2.5V to 7V 60 68 dB PSRR Match (Channel-to-Channel) (Note 11) VS = 2.5V to 10V, LT6201DD VS = 2.5V to 7V 65 100 dB Minimum Supply Voltage (Note 6) 2.5 V 62001ff 3 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Package Description Revision History Typical Application Related Parts
