LT1806/LT1807 ELECTRICAL CHARACTERISTICSThe l denotes the specifi cations which apply over the 0°C < TA < 70°Ctemperature range. VS = 5V, 0V; VS = 3V, 0V; VSHDN = open; VCM = VOUT = half supply, unless otherwise noted.SYMBOLPARAMETERCONDITIONSMINTYPMAXUNITS Input Bias Current Match (Channel-to-Channel) VCM = V+ – 0.2V l 0.03 1.5 μA (Note 10) VCM = V – + 0.4V l 0.05 3.5 μA IOS Input Offset Current VCM = V+ – 0.2V l 0.03 0.75 μA VCM = V – + 0.4V l 0.05 1.80 μA ΔIOS Input Offset Current Shift VCM = V – + 0.4V to V+ – 0.2V l 0.08 2.55 μA AVOL Large-Signal Voltage Gain VS = 5V, VO = 0.5V to 4.5V, RL = 1k to VS/2 l 60 175 V/mV VS = 5V, VO = 1V to 4V, RL = 100Ω to VS/2 l 7.5 20 V/mV VS = 3V, VO = 0.5V to 2.5V, RL = 1k to VS/2 l 45 140 V/mV CMRR Common Mode Rejection Ratio VS = 5V, VCM = V – to V+ l 77 94 dB VS = 3V, VCM = V – to V+ l 72 89 dB CMRR Match (Channel-to-Channel) (Note 10) VS = 5V, VCM = V – to V+ l 71 94 dB VS = 3V, VCM = V – to V+ l 66 89 dB Input Common Mode Range l V – V+ V PSRR Power Supply Rejection Ratio VS = 2.5V to 10V, VCM = 0V l 88 105 dB PSRR Match (Channel-to-Channel) (Note 10) VS = 2.5V to 10V, VCM = 0V l 82 105 dB Minimum Supply Voltage (Note 6) VCM = VO = 0.5V l 2.3 2.5 V VOL Output Voltage Swing Low (Note 7) No Load l 12 60 mV ISINK = 5mA l 60 140 mV ISINK = 25mA l 180 425 mV VOH Output Voltage Swing High (Note 7) No Load l 30 120 mV ISOURCE = 5mA l 110 220 mV ISOURCE = 25mA l 360 700 mV ISC Short-Circuit Current VS = 5V l ±30 ±65 mA VS = 3V l ±25 ±55 mA IS Supply Current per Amplifi er l 10 14 mA Disable Supply Current VS = 5V, VSHDN = 0.3V l 0.40 1.1 mA VS = 3V, VSHDN = 0.3V l 0.22 0.9 mA ISHDN SHDN Pin Current VS = 5V, VSHDN = 0.3V l 160 400 μA VS = 3V, VSHDN = 0.3V l 110 350 μA Shutdown Output Leakage Current VSHDN = 0.3V l 1 μA VL SHDN Pin Input Voltage Low l 0.3 V VH SHDN Pin Input Voltage High l V+ – 0.5 V tON Turn-On Time VSHDN = 0.3V to 4.5V, RL = 100Ω l 80 ns tOFF Turn-Off Time VSHDN = 4.5V to 0.3V, RL = 100Ω l 50 ns GBW Gain-Bandwidth Product Frequency = 6MHz l 300 MHz SR Slew Rate VS = 5V, AV = –1, RL= 1k, VO = 4V l 100 V/μs FPBW Full-Power Bandwidth VS = 5V, VO = 4VP-P l 8 MHz 18067fc 5
