Datasheet LT1806, LT1807 (Analog Devices) - 10
Description325MHz, Single, Rail-to-Rail Input and Output, Low Distortion, Low Noise Precision Op Amps
Pages / Page28 / 10 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 346 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the. 40°C < TA < 85°C
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the 40°C < TA < 85°C
LT1806/LT1807
l
40°C < TA < 85°C temperature range. VS =
5V, VSHDN = open; VCM = 0V, VOUT = 0V, unless otherwise noted. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage VCM = V+ l 200 900 μV VCM = V – l 200 900 μV VCM = V+ (LT1806 SOT-23) l 200 975 μV VCM = V – (LT1806 SOT-23) l 200 975 μV VOS TC Input Offset Voltage Drift (Note 8) VCM = V+ l 1.5 5 μV/°C VCM = V – l 1.5 5 μV/°C ΔV l OS Input Offset Voltage Shift VCM = V – to V+ 100 900 μV VCM = V – to V+ (LT1806 SOT-23) l 100 975 μV Input Offset Voltage Match (Channel-to-Channel) VCM = V –, VCM = V+ l 300 1600 μV (Note 10) IB Input Bias Current VCM = V+ – 0.2V l 1.2 7 μA VCM = V – + 0.4V l –16 –5 μA ΔIB Input Bias Current Shift VCM = V – + 0.4V to V+ – 0.2V l 6 23 μA Input Bias Current Match (Channel-to-Channel) VCM = V+ – 0.2V l 0.03 2 μA (Note 10) VCM = V – + 0.4V l 0.04 4.5 μA IOS Input Offset Current VCM = V+ – 0.2V l 0.03 1.0 μA VCM = V – + 0.4V l 0.04 2.2 μA ΔIOS Input Offset Current Shift VCM = V – + 0.4V to V+ – 0.2V l 0.07 3.2 μA AVOL Large-Signal Voltage Gain VO = –4V to 4V, RL = 1k l 60 175 V/mV VO = –2V to 2V, RL =100Ω l 7 17 V/mV CMRR Common Mode Rejection Ratio VCM = V – to V+ l 80 100 dB CMRR Match (Channel-to-Channel) (Note 10) VCM = V – to V+ l 74 100 dB Input Common Mode Range l V – V+ V PSRR Power Supply Rejection Ratio V+ = 2.5V to 10V, V – = 0V l 86 105 dB PSRR Match (Channel-to-Channel) (Note 10) l 80 105 dB VOL Output Voltage Swing Low (Note 7) No Load l 20 100 mV ISINK = 5mA l 65 170 mV ISINK = 20mA l 200 500 mV VOH Output Voltage Swing High (Note 7) No Load l 50 160 mV ISOURCE = 5mA l 115 260 mV ISOURCE = 20mA l 360 700 mV ISC Short-Circuit Current l ±25 ±55 mA IS Supply Current per Amplifi er l 15 22 mA Disable Supply Current VSHDN = 0.3V l 0.45 1.5 mA ISHDN SHDN Pin Current VSHDN = 0.3V l 170 400 μA Shutdown Output Leakage Current VSHDN = 0.3V l 1.2 μA VL SHDN Pin Input Voltage Low l 0.3 V VH SHDN Pin Input Voltage High l V+ – 0.5 V tON Turn-On Time VSHDN = 0.3V to 4.5V, RL = 100Ω l 80 ns 18067fc 10
