Datasheet LT1806, LT1807 (Analog Devices) - 8
Description325MHz, Single, Rail-to-Rail Input and Output, Low Distortion, Low Noise Precision Op Amps
Pages / Page28 / 8 — ELECTRICAL CHARACTERISTICS. TA = 25°C. VS =. 5V, VSHDN = open; VCM = 0V, …
File Format / SizePDF / 346 Kb
ELECTRICAL CHARACTERISTICS. TA = 25°C. VS =. 5V, VSHDN = open; VCM = 0V, VOUT = 0V, unless otherwise noted. SYMBOL. PARAMETER
ELECTRICAL CHARACTERISTICS TA = 25°C VS = 5V, VSHDN = open; VCM = 0V, VOUT = 0V, unless otherwise noted SYMBOL PARAMETER
LT1806/LT1807
ELECTRICAL CHARACTERISTICS TA = 25°C. VS =
5V, VSHDN = open; VCM = 0V, VOUT = 0V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
CMRR Common Mode Rejection Ratio VCM = V – to V+ 83 106 dB CMRR Match (Channel-to-Channel) (Note 10) VCM = V – to V+ 77 106 dB Input Common Mode Range V – V+ V PSRR Power Supply Rejection Ratio V+ = 2.5V to 10V, V – = 0V 90 105 dB PSRR Match (Channel-to-Channel) (Note 10) V+ = 2.5V to 10V, V – = 0V 84 105 dB VOL Output Voltage Swing Low (Note 7) No Load 14 60 mV ISINK = 5mA 55 140 mV ISINK = 25mA 180 450 mV VOH Output Voltage Swing High (Note 7) No Load 20 70 mV ISOURCE = 5mA 90 200 mV ISOURCE = 25mA 360 700 mV ISC Short-Circuit Current ±40 ±85 mA IS Supply Current per Amplifi er 11 16 mA Disable Supply Current VSHDN = 0.3V 0.4 1.2 mA ISHDN SHDN Pin Current VSHDN = 0.3V 150 350 μA Shutdown Output Leakage Current VSHDN = 0.3V 0.3 75 μA VL SHDN Pin Input Voltage Low 0.3 V VH SHDN Pin Input Voltage High V+ – 0.5 V tON Turn-On Time VSHDN = 0.3V to 4.5V, RL = 100Ω 80 ns tOFF Turn-Off Time VSHDN = 4.5V to 0.3V, RL = 100Ω 50 ns GBW Gain-Bandwidth Product Frequency = 6MHz 170 325 MHz SR Slew Rate AV = –1, RL = 1k, VO = ±4V, Measured at VO = ±3V 70 140 V/μs FPBW Full-Power Bandwidth VO = 8VP-P 5.5 MHz HD Harmonic Distortion AV = 1, RL = 1k, VO = 2VP-P, fC = 5MHz – 80 dBc tS Settling Time 0.01%, VSTEP = 8V, AV = 1, RL = 1k 120 ns ΔG Differential Gain (NTSC) AV = 2, RL = 150 0.01 % Δθ Differential Phase (NTSC) AV = 2, RL = 150 0.01 Deg 18067fc 8
