Datasheet LT1364, LT1365 (Analog Devices) - 12
DescriptionDual and Quad 70MHz, 1000V/µs Op Amps
Pages / Page12 / 12 — TYPICAL APPLICATIONS. Two Op Amp Instrumentation Amplifier. 2MHz, 4th …
File Format / SizePDF / 230 Kb
TYPICAL APPLICATIONS. Two Op Amp Instrumentation Amplifier. 2MHz, 4th Order Butterworth Filter
TYPICAL APPLICATIONS Two Op Amp Instrumentation Amplifier 2MHz, 4th Order Butterworth Filter
LT1364/LT1365
U TYPICAL APPLICATIONS Two Op Amp Instrumentation Amplifier 2MHz, 4th Order Butterworth Filter
R5 R4 220Ω 10k 464Ω 549Ω R1 R2 47pF 10k 1k 22pF 464Ω 1.33k R3 – VIN – 1k 549Ω 1.13k 1/2 1/2 – 220pF – LT1364 LT1364 1/2 – + 1/2 V + OUT 470pF V LT1364 OUT LT1364 VIN + + + 1364/1365 TA04    4  1 2 3 ( 2 3) R     R R  R + R GAIN =   1+  = 102 R3  2 R1 R4 R     +   + 5    TRIM R5 FOR GAIN TRIM R1 FOR COMMON-MODE REJECTION 1364/1365 TA01 BW = 700kHz
U PACKAGE DESCRIPTION Dimension in inches (millimeters) unless otherwise noted. S8 Package 8-Lead Plastic Small Outline (Narrow 0.150)
(LTC DWG # 05-08-1610) 0.189 – 0.197* (4.801 – 5.004) 0.010 – 0.020 × 45° 0.053 – 0.069 8 7 6 5 (0.254 – 0.508) (1.346 – 1.752) 0.004 – 0.010 0.008 – 0.010 0 (0.101 – 0.254) (0.203 – 0.254) °– 8° TYP 0.228 – 0.244 0.150 – 0.157** 0.016 – 0.050 (5.791 – 6.197) (3.810 – 3.988) 0.014 – 0.019 0.050 (0.406 – 1.270) (0.355 – 0.483) (1.270) TYP BSC *DIMENSION DOES NOT INCLUDE MOLD FLASH. MOLD FLASH SHALL NOT EXCEED 0.006" (0.152mm) PER SIDE **DIMENSION DOES NOT INCLUDE INTERLEAD FLASH. INTERLEAD 1 2 3 4 FLASH SHALL NOT EXCEED 0.010" (0.254mm) PER SIDE SO8 1298
S Package 16-Lead Plastic Small Outline (Narrow 0.150)
(LTC DWG # 05-08-1610) 0.386 – 0.394* (9.804 – 10.008) 0.010 – 0.020 × 45° 0.053 – 0.069 12 11 10 0.004 – 0.010 16 15 14 13 9 (0.254 – 0.508) (1.346 – 1.752) (0.101 – 0.254) 0.008 – 0.010 (0.203 – 0.254) 0° – 8° TYP 0.228 – 0.244 0.150 – 0.157** (5.791 – 6.197) (3.810 – 3.988) 0.014 – 0.019 0.050 0.016 – 0.050 (0.355 – 0.483) (1.270) (0.406 – 1.270) TYP BSC *DIMENSION DOES NOT INCLUDE MOLD FLASH. MOLD FLASH SHALL NOT EXCEED 0.006" (0.152mm) PER SIDE **DIMENSION DOES NOT INCLUDE INTERLEAD FLASH. INTERLEAD 1 2 3 4 5 6 7 8 S16 1098 FLASH SHALL NOT EXCEED 0.010" (0.254mm) PER SIDE
RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LT1363 70MHz, 1000V/µs Op Amp Single Version of LT1364/LT1365 LT1361/LT1362 Dual and Quad 50MHz, 800V/µs Op Amps Lower Power Version of LT1364/LT1365, VOS = 1mV, 4mA/Amplifier LT1358/LT1359 Dual and Quad 25MHz, 600V/µs Op Amps Lower Power Version of LT1364/LT1365, VOS = 0.6mV, 2mA/Amplifier LT1813 Dual 100MHz, 700V/µs Op Amps Low Voltage, Low Power LT1364/LT1365, 3mA/Amplifier 13645fa LT/TP 0400 2K REV A • PRINTED IN USA 12 Linear Technology Corporation 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear-tech.com LINEAR TECHNOLOGY CORPORATION 1994
