Datasheet LT1195 (Analog Devices) - 2
DescriptionLow Power, High Speed Operational Amplifier
Pages / Page12 / 2 — ABSOLUTE AXI U RATI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). (OBSOLETE). …
File Format / SizePDF / 347 Kb
ABSOLUTE AXI U RATI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). (OBSOLETE). OBSOLETE PACKAGE. +5V ELECTRICAL CHARACTERISTICS TA = 25
ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Note 1) (OBSOLETE) OBSOLETE PACKAGE +5V ELECTRICAL CHARACTERISTICS TA = 25
LT1195
W W W U U W U ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Note 1)
TOP VIEW ORDER PART Total Supply Voltage (V+ to V–) ... 18V BAL 1 BAL NUMBER 8 Differential Input Voltage ... ±6V –IN 2 7 V+ Input Voltage ... ±V LT1195CN8 S +IN 3 6 OUT Output Short-Circuit Duration (Note 2) ... Continuous LT1195CS8 V– 4 5 S/D Operating Temperature Range S8 PART MARKING LT1195M
(OBSOLETE)
... –55°C to 125°C N8 PACKAGE S8 PACKAGE 8-LEAD PDIP 8-LEAD PLASTIC SO 1195 LT1195C .. 0°C to 70°C TJMAX = 150°C, θJA = 100°C/ W (N8) Junction Temperature (Note 3) TJMAX = 150°C, θJA = 150°C/ W (S8) ORDER PART Plastic Package (CN8, CS8) .. 150°C NUMBER Ceramic Package (CJ8, MJ8)
(OBSOLETE)
... 175 J8 PACKAGE °C 8-LEAD CERDIP LT1195MJ8 Storage Temperature Range ... –65°C to 150°C TJMAX = 150°C, θJA = 100°C/ W (J8) LT1195CJ8 Lead Temperature (Soldering, 10 sec).. 300°C
OBSOLETE PACKAGE
Consider the N8 or S8 Package for Alternate Source Consult LTC Marketing for parts specified with wider operating temperature ranges.
C VS =
5V, CL
10pF, Pin 5 open circuit, unless otherwise noted. LT1195M/C SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage J8, N8 Package 3.0 8.0 mV S8 Package 3.0 10.0 mV IOS Input Offset Current 0.2 1.0 µA IB Input Bias Current ±0.5 ±2.0 µA en Input Noise Voltage fO = 10kHz 70 nV√Hz in Input Noise Current fO = 10kHz 2 pA√Hz RIN Input Resistance Differential Mode 230 kΩ Common Mode 20 MΩ CIN Input Capacitance AV = 1 2.2 pF Input Voltage Range (Note 4) –2.5 3.5 V CMRR Common Mode Rejection Ratio VCM = –2.5 to 3.5V 60 85 dB PSRR Power Supply Rejection Ratio VS = ±2.375V to ±8V 60 85 dB AVOL Large-Signal Voltage Gain RL = 1k, VOUT = ±3V 2.0 7.5 V/mV RL = 150Ω, VOUT = ±3V 0.5 1.5 V/mV VS = ±8V, RL = 1k, VOUT = ±5V 11.0 V/mV VOUT Output Voltage Swing VS = ±5V, RL = 1k ±3.8 ±4.0 V VS = ±8V, RL = 1k ±6.7 ±7.0 V SR Slew Rate AV = –1, RL = 1k (Note 5, 10) 110 165 V/µs FPBW Full Power Bandwidth VOUT = 6VP-P (Note 6) 8.75 MHz GBW Gain-Bandwidth Product 50 MHz tr1, tf1 Rise Time, Fall Time AV = 50, VOUT = ±1.5V, 20% to 80% (Note 10) 125 170 285 ns tr2, tf2 Rise Time, Fall Time AV = 1, VOUT = ±125mV, 10% to 90% 3.4 ns tPD Propagation Delay AV = 1, VOUT = ±125mV, 50% to 50% 2.5 ns Overshoot AV = 1, VOUT = ±125mV 22 % tS Settling Time 3V Step, 0.1% (Note 7) 220 ns Diff AV Differential Gain RL = 150Ω, AV = 2 (Note 8) 1.25 % Diff Ph Differential Phase RL = 150Ω, AV = 2 (Note 8) 0.86 DEGP-P 1195fa 2
