Datasheet LT1007, LT1037 (Analog Devices) - 8
Description | Low Noise, High Speed Precision Operational Amplifiers |
Pages / Page | 16 / 8 — TYPICAL PERFORMANCE CHARACTERISTICS. LT1037 Phase Margin, Gain. LT1037 … |
File Format / Size | PDF / 532 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. LT1037 Phase Margin, Gain. LT1037 Small-Signal. Bandwidth Product, Slew Rate vs
LT1007/LT1037
W U TYPICAL PERFORMANCE CHARACTERISTICS LT1037 Phase Margin, Gain LT1037 Small-Signal Bandwidth Product, Slew Rate vs Transient Response LT1037 Large-Signal Response Temperature
GAIN BANDWIDTH PROCUCT, f 70 VS = ±15V CL = 100pF 10V 60 50mV PHASE MARGIN 70 0V 0V 50 60 GBW – 50mV – 10V s) PHASE MARGIN (DEG) µ 20 O = 10kHz (MHz) 50 SLEW 15 AVCL = 5 AVCL = 5 VS = ±15V VS = ±15V 1007/37 G29 CL = 15pF 1007/37 G28 SLEW RATE (V/ 10 –50 –25 0 25 50 75 100 125 TEMPERATURE (°C) 1007/37 G30
LT1007 Phase Margin, Gain LT1037 Gain, Phase Shift LT1007 Gain, Phase Shift Bandwidth Product, Slew Rate vs vs Frequency vs Frequency Temperature
GAIN BANDWIDTH PROCUCT, f 50 90 40 90 70 VS = ±15V VS = ±15V V 100 100 S = ±15V T T A = 25°C A = 25°C CL = 100pF 40 CL = 100pF 110 30 CL = 100pF 110 60 PHASE SHIFT (DEG) PHASE SHIFT (DEG) PHASE MARGIN 120 120 9 30 PHASE 130 20 130 50 PHASE 140 140 GBW 8 20 150 10 GAIN 150 µs) PHASE MARGIN (DEG) 3 O GAIN SLEW = 100kHz (MHz) VOLTAGE GAIN (dB) 160 VOLTAGE GAIN (dB) 160 7 AV = 5 10 170 0 170 2 180 180 SLEW RATE (V/ 0 190 –10 190 1 0.1 1 10 100 0.1 1 10 100 –50 –25 0 25 50 75 100 125 FREQUENCY (MHz) FREQUENCY (MHz) TEMPERATURE (°C) 1007/37 G31 1007/37 G32 1007/37 G33
LT1007 Small-Signal Maximum Undistorted Output Transient Response LT1007 Large-Signal Response vs Frequency
28 VS = ±15V 24 TA = 25°C 50mV 5V 20 0V 0V 16 LT1007 LT1037 – 50mV 12 – 5V 8 A A VCL = 1 VCL = – 1 4 V V PEAK-TO-PEAK OUTPUT VOLTAGE (V) S = ±15V S = ±15V 1007/37 G35 CL = 15pF 1007/37 G34 0 1k 10k 100k 1M 10M FREQUENCY (Hz) 1007/37 G36 sn100737 100737fbs 8
