Datasheet LT6015, LT6016, LT6017 (Analog Devices) - 7
Description3.2MHz, 0.8V/μs Low Power, Over-The-Top Precision Op Amps
Pages / Page22 / 7 — elecTrical characTerisTics The. denotes the specifications which apply …
elecTrical characTerisTics The. denotes the specifications which apply over the specified temperature
elecTrical characTerisTics The denotes the specifications which apply over the specified temperature
LT6015/LT6016/LT6017
denotes the specifications which apply over the specified temperature range, –55°C < TJUNCTION < 150°C for MP-grade parts, otherwise specifications are at TA = 25°C, VS = ±15V, VCM = VOUT = Mid-Supply. MP-GRADE SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
RINCM Common Mode Input Resistance 0 < VCM < V+ – 1.75V >1 GΩ VCM > V+ >100 MΩ en Input Referred Noise Voltage Density f = 1kHz VCM < V+ – 1.75V 18 nV/√Hz VCM > V+ 25 nV/√Hz Input Referred Noise Voltage f = 0.1Hz to 10Hz 0.5 µVP-P VCM < V+ – 1.75V in Input Referred Noise Current Density f = 1kHz VCM < V+ – 1.75V 0.1 pA/√Hz VCM > V+ 11.5 pA/√Hz AVOL Open Loop Gain RL = 10kΩ l 100 1000 V/mV ∆VOUT = 27V PSRR Supply Rejection Ratio VS = ±2.5V to ±25V l 106 126 dB VCM = VOUT = 0V CMRR Input Common Mode Rejection Ratio VCM = –15V to 13.25V l 100 126 dB VOL Output Voltage Swing Low VS = ±15V, No Load l 3 75 mV VS = ±15V, ISINK = 5mA l 280 550 mV VOH Output Voltage Swing High VS = ±15V, No Load l 450 750 mV VS = ±15V, ISOURCE = 5mA l 1000 1300 mV ISC Short-Circuit Current VS = ±15V, 50Ω to GND l 8 30 mA VS = ±15V, 50Ω to GND l 8 32 mA GBW Gain Bandwidth Product fTEST = 100kHz 2.9 3.3 MHz l 2.45 3.3 MHz SR Slew Rate ∆VOUT = 3V 0.6 0.8 V/µs l 0.45 0.8 V/µs tS Settling Time Due to Input Step 0.1% Settling 3.5 µs ∆VOUT = ±2V VS Supply Voltage 3 50 V l 3.3 50 V Reverse Supply IS = –25µA/Amplifier l –65 –30 V IS Supply Current Per Amplifier SOT-23 Package 325 360 µA MS8, DJC22 Packages 325 350 µA l 325 575 µA VS = ±25V, SOT-23 Package 340 370 µA VS = ±25V, MS8, DJC22 Package 340 360 µA VS = ±25V l 340 600 µA RO Output Impedance ∆IO = ±5mA 0.15 Ω
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings The LT6015MP/LT6016MP/LT6017MP are guaranteed functional over the may cause permanent damage to the device. Exposure to any Absolute junction temperature range of –55°C to 150°C. Junction temperatures greater Maximum Rating condition for extended periods may affect device than 125°C will promote accelerated aging. The LT6015/LT6016/LT6017 has a reliability and lifetime. demonstrated typical performance beyond 1000 hours at TJ = 150°C.
Note 2:
Voltages applied are with respect to V–. The inputs are tested to
Note 5:
The LT6015I/LT6016I/LT6017I are guaranteed to meet specified the Absolute Maximum Rating by applying –25V (relative to V–) to each performance from –40°C to 85°C. The LT6015H/LT6016H/LT6017H are input for 10ms. In general, faults capable of sinking current from either guaranteed to meet specified performance from –40°C to 125°C. The input should be current limited to under 10mA. See the Applications LT6015MP/LT6016MP/LT6017MP are guaranteed to meet specified Information section for more details. performance with junction temperature ranging from –55°C to 150°C.
Note 3:
A heat sink may be required to keep the junction temperature
Note 6:
Test accuracy is limited by high speed test equipment repeatability. Bench below absolute maximum. This depends on the power supply voltage and measurements indicate the input offset current in the Over-The-Top configuration how many amplifiers are shorted. is typically controlled to under ±50nA at 25°C and ±150nA over temperature.
Note 4:
The LT6015I/LT6016I/LT6017I are guaranteed functional over the oper-
Note 7:
The Reverse Supply voltage is tested by pulling 25μA/Amplifier out ating temperature range of –40°C to 85°C. The LT6015H/LT6016H/LT6017H are of the V+ pin while measuring the V+ pin’s voltage with both inputs and V– guaranteed functional over the operating temperature range of –40°C to 125°C. grounded, verifying V+ < –50V. 601567ff For more information www.linear.com/LT6015 7 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Simplified Schematic Typical Applications Package Description Revision History Related Parts
